Stern Gallery Window Acetate Options
#1 Posted : 24 September 2013 19:04:17
Help! Does anyone have a spare windows acetate sheet that came with issue 56, as you can see in build diary I cut mine up into 3 strips and the cat has gone and taken the middle window strip, cats have a lot to answer to in this forumCursing
I found it but it is creased and slightly chewed and now no good to use.I tried heating it in hot water to reshape it but no good, it is too badly damaged. Perhaps someone who used the MWG enhancement has one lying around - I am prepared to buy this obviuosly.
Thanks
#2 Posted : 24 September 2013 21:05:00
Thanks
Sorry to hear that but interested to hear that other cats love the taste of plastic - thought it was just my mad cat.
Sure the guys and gals will help if possible but should there be no spares check out the back issues on the shop site. Cheaper than eBay and free postage.
Kind regards
#3 Posted : 24 September 2013 21:19:53
I just thought id ask here 1st as it may be quicker than a back order as im right in the middle of doing the gallery now, the cat dosent normally go for plastic, looks like she only chewed it a couple of times but its still too bad to use.
#4 Posted : 24 September 2013 21:33:38
Hi Stevie-O
In order to glaze my own (smaller) stern gallery windows I used the clear acetate that came on the front of the packs containing my Earth-Moon-Sun brass "Orrery" pieces.
Any item that comes in one of those packs with a clear moulded front and clear or cardboard back will provide tons of the stuff. You could either add the frames on with a very fine permanent marker (tends to fade over time though) or else apply thin strips of black insulation tape or even make new frames from brass rod as I did!
Either way, there's no need to spend a lot on acetate, there's plenty out there for free!BigGrin
Hope this helps
Robin
#5 Posted : 24 September 2013 21:38:57
I agree 100% with plymouth. brass wire would do the trick,looks better I think with clear acetate. good luck.
#6 Posted : 24 September 2013 21:52:57
Hi,
Thanks for the replies, unfortunatly as you will see from my recent post in build diary I have already fitted the lower windows, although I suppose I could pull it off, but Im not sure if i want to
#7 Posted : 24 September 2013 22:40:15
Hi Steve, sorry to hear your moggies chewing habits.... I bought the gallery enhancement kit from Mike and thought I would send you the acetate I don't need then I realised a problem. I am just about to receive my next Vic pack but it only takes me up to issue 50 and your parts are in issue 56... Crying Crying . Would take another 2 months anyways before I have what you are looking for but would be happy to send it if you want to wait... Blink Blink
#8 Posted : 25 September 2013 10:00:24
Thanks for the kind offer Alan, but seeing as there dosent seem to be anyone who has this part now then I think I will be going with the clear acetate and re-doing the lower windows also. I'm right in the middle of this gallery now so 2 months will seem like an eternity for meBigGrin, I know you are supposed to be patient as a model maker but I'm not at all, I cant wait for anything.
Thanks again
#9 Posted : 25 September 2013 12:24:11
hi Stevie_
Just read your post,I think I may have one, have a look tonight and get back to you.
Regards Trev.
#10 Posted : 25 September 2013 12:45:42
#11 Posted : 25 September 2013 13:14:28
Sorry only just spotted this I have used clear so may still have the kit part. I will have a look and if you still need it you can have it.
J
#12 Posted : 25 September 2013 13:22:46
janzwart
#13 Posted : 25 September 2013 19:24:18
Rank: Beginner Level 3
Steve,
I didn't use mine. You can have it if still needed.
Let me know with a pm.
Jan Zwart
Current build: HMS Victory
Already built: Half moon, Stadt Bremen.
#14 Posted : 25 September 2013 20:45:45
#15 Posted : 25 September 2013 22:05:54
Ok Steve thanks for letting me no.
Regards Trev.
