Joined: 29/04/2010 Posts: 31 Points: 69 Location: scunthorpe
 prob depend how bad the warp is if u are using an iron as long as wet tea towel or cloth is between iron & part the part will be ok once flat remember to weight it till drys out
and if i am not using an iron
Joined: 25/04/2010 Posts: 748 Points: 2,285 Location: bognor regis
hi..you could soak them in warm water for an hour then clamp them between 2 flat surfaces..i use 2 pieces of kitchen work top all my ribs have been there for weeks now cheers benny
