4 Pages <1234>
Karl's build of the Schooner "Virginia" 1819. Options
#21 Posted : 19 September 2013 13:33:27
looking Good Karl. know how feel I am finding ther same with the Dohw. I think you can see progress so quickly it spurs you on to the nex Task Cool
#22 Posted : 19 September 2013 15:10:15
It sure does jase,so the planking has started,the first plank laid if for spacing only,the gunwales are fitted last to this gap after removing first plank.at this stage it's worth looking at the overall shape of the hull,the bow and stern sections have a smaller area then the centre of the hull so reducing the next lot of planks is nessessary.I have tapered the next plank 3 formers in at the bow,and 3 formers in at the stern.the amount of tapering is governed by the shipyards rules of 1/2 width tapering to nothing,so you don't get pointed bit of planking,so far no stealers have been used,but will say if I need to use them.
#23 Posted : 19 September 2013 15:11:27
#24 Posted : 19 September 2013 15:15:00
#25 Posted : 19 September 2013 15:21:15
as you can see,I used the crimper type plank bender,and soaked each plank for 30 seconds,because this is a small boat,I have use medium superglue for the fixing agent.had it been a larger vessel,I would have use aliphatic glue.I also bevel each plank to get a nice tight fit,and having soaked the planks I can twist them to stop the clinkering effect.total build time to date 13 hours.
#26 Posted : 20 September 2013 16:04:57
that's the first layer done,just the sanding down to do .before I start the second layer,I have to put a couple of coats of shellac sanding cleaner.
#27 Posted : 20 September 2013 22:04:25
Looking great Karl, can really see her shape now.... Cool Cool
jonny7england
#28 Posted : 21 September 2013 12:02:24
Looking great Karl..Steaming along mate!! ThumpUp
#29 Posted : 21 September 2013 12:43:44
Love the lines of this model Cool
#30 Posted : 21 September 2013 12:46:33
thanks for droppin' in gents. getting in the grove now.Cool
#31 Posted : 21 September 2013 15:36:58
BigGrin Nice bit of planking Karl love it Woot Rgd Martyn
#32 Posted : 23 September 2013 14:55:34
#33 Posted : 23 September 2013 15:01:01
with the second layer of planking done,I then glued the wales.the rudder post,false keel and tiller to do next. 20 build hours to date.
#34 Posted : 23 September 2013 21:07:02
Looking good mate
J
#35 Posted : 23 September 2013 22:29:56
Nicely done Karl, going to be another lovely looking build.... Cool Cool
#36 Posted : 24 September 2013 14:50:46
two coats of shellac sanding sealer, inner rail supports fitted,and false keels fitted.
#37 Posted : 24 September 2013 17:11:18
BigGrin Looking good KarlCool
#38 Posted : 24 September 2013 18:23:13
BigGrin Nice work Karl ThumpUp Rgd Martyn
#39 Posted : 24 September 2013 21:19:47
Karl
Been keeping up with your builds and as ever just do not know how you do it. I bet you never sleep BigGrin
I take my hat off (if I had one) to your planking. I think that cotton trick you use for your plank caulking is brilliant. But how you do it is beyond me - tried it and decided you need at least 4 hands.
Many thanks again for sharing all your builds which I really appreciate. Don't always have the time to comment but always impressed with what you do.
Kind regards
#40 Posted : 24 September 2013 21:26:07
4 Pages <1234>
