quarterdeck & forcastle cladding Options
jethro
#1 Posted : 13 September 2013 10:33:15
when I saw the method for cladding the quarterdeck and smoothing and painting after fitting "issue 46" I thought it a bit tricky not to damage the surrounding area. So what I did was, with a glass jar of similar curvature stuck masking tape around the bottom of this sticky side out and stuck the bamboo stripes precut round the tape/jar, then I could smooth and paint them. When paint was dry go round this with more tape, cut tape to remove cladding in sections, take of inner tape. Glue in place so no damage to decking, and remove tape. In hindsight I would use stronger tape on the inside.
riff-raff
#2 Posted : 22 September 2013 10:21:42
I used sheets of veneer instead - no pre-bending and no sanding - much easier than the supplied instructions and a nicer finish.
Built:
court orchard
#3 Posted : 22 September 2013 10:44:03
I agree the method suggested seems very awkward, I plan to use 0.4mm Ply and face with Black Boxwood.
#4 Posted : 22 September 2013 10:46:12
Have to say I did find it rather awkward but with a little bit of care it can be done to a nice standard... Look forward to seeing all the diffent ways other modellers will tackle this issue.... Cool Cool
This page was generated in 0.147 seconds.
