Shock settings Options
Ford62
#1 Posted : 09 September 2013 00:38:22
Hi Guys
Should the shock settings of 8mm be set prior to putting on the spring
i.e. Distance between Shock case & Ball end
up to issues 24 - 27
Thanks
rowdy85
#2 Posted : 10 September 2013 06:57:37
Taken from Tomick's Official build diary:- "The distance from the ball end and the shock case should be set at 8mm for both front shocks.
At 8mm the ground clearance of the model is set to neutral. If you want a lower ground clearance at the front, then adjust the distance of both front shocks to 7mm.
To increase the ground clearance, you can set the distance to 9mm."
So by that I think we are to adjust the shock length by screwing the ball ends further on or off. Confused
#3 Posted : 10 September 2013 09:05:22
Set with spring off, as per step 22 of issue 26.
Correct, the adjustment is set via the ball socket.
This page was generated in 0.102 seconds.
