 Rank: Pro   Groups: Joined: 01/01/2013 Posts: 149 Points: 459
the figures,fantastic Best regards, Reiner
Thanks for the comments guys. Just to let you know I am still progressing with this but slow going as I still receive the parts each month so im restricted to how fast I can go. Anyway, I have now painted all 80 something HAT figures and completed the main and fore mast and all 6 yards for these 2 masts. The mizzen mast must come a lot later in the build. I have now wrapped these up and put them away for a while to keep them safe as its back to work on the hull now. More pics soon. stevie_o attached the following image(s):
Just completed the entrance canopies on issue 74. After painting the trim gold as suggested in the guide, I though the channel between the two gold trim lines on the canopy supports was a bit plain so I decided to add a little more detail. I painted 1 piece of solder black and another gold and made a twist, I then pressed these into the recessed channel, sized them up first and then glued them in. The solder bends nicely to fit the parts and can be trimmed with a blade. A little coat of gloss varnish to complete! stevie_o attached the following image(s):
nice touch “Whenever you find yourself on the side of the majority, it is time to pause and reflect.” -Mark Twain
Joined: 01/04/2013 Posts: 342 Points: 1,029 Location: Essex
Nice job Steve Regards Alan England expects that every man will do his duty.
Hi Stevie, Some very nice added detail in there. Following with interest, Regards delboy271155 (Derek) COME BACK GUY FAWKES "YOUR COUNTRY NEEDS YOU"
What a fab idea to use solder, impressive work Steve.... very well done...
 Very nice work and you have reminded me how usefull solder wire can be Steve keep it up Andy Current builds:-C57,Zero, Lamborghini Countach, Caldercraft HMS Agamemnon,Robi,R2-D2, MFH Cobra .
Well done, Steve looks brilliant and good tip. Rgds, Hans "It's okay to make mistakes. mistakes are our teachers - they help us to to learn, even if it is painfully" Current Build: Endeavour Cross section,D51 Completed: HMS Victory Under the bench: Endeavour x 2,Sovereign of the Seas, Akagi and The Black Pearl!HMS Victory Cross Section
Hi Everyone, just been plodding along with this up to issue 80 now, not much to report so i will just pop some pics of all the new additions since the last entry, pictures speak louder than words, or so they say stevie_o attached the following image(s):
Joined: 16/07/2011 Posts: 165 Points: 457 Location: South Wales
Hi Stevie Looks fabulous. Keep up the good work. Regards. Gareth Completed models,Hachette Titanic.Deags. Hms Victory. Hachette Hems Hood.Ongoing builds. Deags Akagi,Deags Sovereign of the Seas,Deags Spitfire,On my wish list.Yamato.Royal Navy world war 2 aircraft carrier.
Beautiful paintwork, another masterpiece looms.
Hi Stevie, love it, so clean and precise.... Very well done... Regards Alan
 Rank: Amateur level 2     Groups: Registered
Joined: 09/07/2013 Posts: 41 Points: 123 Location: Alberton, South Africa
Hi Stevie, Earlier on in your build you mentioned that you used "weather it" on your deck planking, as well as Danish oil. I think that your deck planking is absolutely stunning and just wondered if you had any more info on the "weather it" and Danish oil. We are a little isolated in South Africa  .I'd like to find out if there is anywhere here that I could get the stuff. Love your Victory Present Build: San Fransisco II, 1/32 Lancaster Bomber
Subscribed to: Sovereign of the Seas
Completed: La Toulonnaise, Harvey
Joined: 30/06/2011 Posts: 51 Points: 133 Location: barnsley
Stunning build an excellent touch using solder on the hatch. Ongoing Builds Deag HMS Victory Deag Soveriegn of the Sea
Thanks all so much for the nice comments, more pics to come soon when i get my next installment. Re. The deck planking, this is what i did exactly - After the deck were smoothed down I applied a 50/50 mix of "weather it" and water. I got mine from ebay from this seller - http://www.ebay.co.uk/itm/Weath...&hash=item589b024322it does seem expensive but it will last you for years and many models! This was left to age the wood overnight then I painted on the Danish oil. You can get this in many brands but i used the cheapo one at Wilkos for about £4 for big tin, this will also last you for many models. I know you wont get the exact one if you are in SA but here is the one i got so you can get an equivilent - http://www.wilko.com/garden-fur...65151?VBMST=danish%20oilThen, the next day I did 2 coats of waterbased matt varnish, this dries very fast and i did both coats a hour apart - any varnish will do im sure but again i went for "cheap" and got wilkos here - http://www.wilko.com/interior-w...017?VBMST=matt%20varnishThe varnish, although says matt will add a very slight sheen to the wood, a little more on each coat, i liked the effect after 2 coats so stopped there. Hope all this helps Cheers Steve
 Rank: Pro   Groups: Joined: 04/05/2012 Posts: 362 Points: 1,089
Excellent Work Stevie
 Top work Steve Current builds:-C57,Zero, Lamborghini Countach, Caldercraft HMS Agamemnon,Robi,R2-D2, MFH Cobra .
Fantastic build Steve  The entry ports look amazing,very clever use of solder. Kind Regards Nigel
Well done Steve, and a well earned 'outstanding build' yellow medal
Guest (5)
