Joined: 18/08/2013 Posts: 12 Points: 36 Location: Durban, KZN, south africa
Hey Chaps, Started collecting via CNA from the first edition, got up to 14 and they "lost" my file  so i decided to go the Jacklin route from issue 20, caught up with the collecting after back ordering up to issue 18, now we just hope and pray that all will be arriving soon. Added a few pic's of my build so far, must be honest though, i never did the heating or steaming of the hull planks,  , was that a must do?? Keep sailing. Regards Duane portside attached the following image(s):
Joined: 23/04/2013 Posts: 287 Points: 859 Location: Hartbeespoort, NW, South Africa
Hi Duane Welcome to the forum and good to see another SA build! I'm also new to this hooby and enjoying it!  I'm using steam to bend the planks, found that it keep the form better than if not steamed. I've gone the Jacklin route from issue 5 and after some initial frustrations all is on track now and I'm happy! Enjoy the build! Kobus
Current Build HMS Sovereign of the Seas - First Build
Joined: 16/06/2013 Posts: 284 Points: 859 Location: Cape Town, South Africa
Ahoy Duane, its a pleasure to have you on the forum or on the shipbuild. The SOTS is being planked with Bamboo, which is a strong wood which take strain well. Bending wood consist of moist, heat and steam. You soak the planks in water for a few hours until its soft enough to bend by your hands. Take the plank to your former (a shape like figure) and bend it to the shape needed for the hull fitting. Pin it to the hull without glue and let it dry out before applying glue. If you use heat, always damp the planks first with moisture to prevent the burning of the plank. The natural bending is very time consuming. It uses a weight on one end to pull it to a round shape like a tree in the wind. Read the Glue topics for upgrades on your glue. Marcel "Rather try and fail than had failed to try".Sovereign of the Seas Model Space forum: Marcel's build
 Hi Duane Welcome to the forum and enjoy your build regards Andy Current builds:-C57,Zero, Lamborghini Countach, Caldercraft HMS Agamemnon,Robi,R2-D2, MFH Cobra .
Welcome to the forum. you will find plenty of help if you need it. jase “Whenever you find yourself on the side of the majority, it is time to pause and reflect.” -Mark Twain
Warm welcome to the forum Duane, hope you enjoy you time with us and look forward to seeing your build progressing.... Regards Alan
Hi Duane Welcome to the forum and I hope you enjoy your build.Any problems,don't be afraid to ask,we are all here to help each other Kind Regards Nigel
Welcome to the house of fun Duane. On this forum is all the help you need to make your model your pride and joy. Enjoy your build. Rgds, Hans "It's okay to make mistakes. mistakes are our teachers - they help us to to learn, even if it is painfully" Current Build: Endeavour Cross section,D51 Completed: HMS Victory Under the bench: Endeavour x 2,Sovereign of the Seas, Akagi and The Black Pearl!HMS Victory Cross Section
Appreciate all the welcome notes
Joined: 25/04/2013 Posts: 71 Points: 216 Location: Benoni, South Africa
Welcome Duane... Marcel is quite correct. What I have done in the past is wet the planks and then "dry fit" them onto the hull and leave them overnight. They dry in the shape that need them ad then it makes it easier to glue on and pin.. The planking on the launch (as per your photos), wouldn't require wetting the planks because of the thickness of the strips. Good luck, will look forward to checking out your build progress. Cheers Cuan Current Build: HMS SOTS HMS Victory HMS Surprise
