25 Pages «<1617181920>»
Claret's SOTS Build Diary Options
claret
#341 Posted : 31 August 2013 10:10:19
Hi All,
Once the matt black paint had dried, I cut the doors from a strip of Sapele and sanded them with fine grade sand paper.
the door fittings were cut and filed, and glued to the doors before fitting them. This was fiddly, but seemed much easier and doing it whilst the bulkhead and doors were fitted to the ship.
I then glued the whole assembly to the front of the ship.
I am pleased with the result.
Claret
Also working on:
SOTS.
Waiting in the wings:
finished:
007 Iconic DB5.
NMBROOK
#342 Posted : 31 August 2013 13:34:17
More lovely work ClaretCool She is developing into a superb build
Kind Regards Nigel
KobusBeukes
#343 Posted : 31 August 2013 14:56:59
Hi Claret
The bulkhead looks great! Drool Well done!
Kobus
Current Build
HMS Sovereign of the Seas - First Build
#344 Posted : 31 August 2013 22:07:15
Lovely work Claret, love the doors.... Cool Cool
#345 Posted : 31 August 2013 22:12:58
taking shape, the doors are just the detail to start lifting that big bulkhead, looks great.
J
claret
#346 Posted : 01 September 2013 16:12:25
Hi Nigel, Kobus, Alan & Jase,
Many thanks for looking in and for the encouragement.
Claret
Also working on:
SOTS.
finished:
007 Iconic DB5.
claret
#347 Posted : 09 September 2013 08:33:23
Hi All,
Been busy and done a lot of work, but behind on downloading the pics.
started on the gallery frame. Will sand level once glue has cured.
progress below:
Claret
Also working on:
SOTS.
finished:
007 Iconic DB5.
claret
#348 Posted : 09 September 2013 08:36:28
Hi all,
Whilst waiting for the gallery frames to dry, I did some work on the bow beak. I decided to glue the 3mm strip prior to fitting the beak, as this looked the easier option, but was still fiddly.
Further updates to follow.
Thanks for looking in.
claret
Also working on:
SOTS.
finished:
007 Iconic DB5.
jonny7england
#349 Posted : 09 September 2013 10:07:41
Looking real good Claret...Coming along well!!...ThumpUp
#350 Posted : 09 September 2013 10:46:20
BigGrin Nice work Claret keep the pics coming rgd Martyn BigGrin
NMBROOK
#351 Posted : 09 September 2013 11:06:51
Fabulous work ClaretCool Cool I see you went for the doors,they look brilLove .That can't have been easy as my gallery is wider than stock there,yours must be about 7mm.
Kind Regards Nigel
claret
#352 Posted : 09 September 2013 12:53:09
Hi Martyn & Nigel,
Thanks for your nice comments.
The doors were tricky. Made from a Sapele strip. I had a crescent shaped scalpel blade that was used to cut the shape at the top of the door in one cut.
Copper wire painted gold for the hinges.
Claret
Also working on:
SOTS.
finished:
007 Iconic DB5.
#353 Posted : 09 September 2013 19:25:52
Hi Claret,BigGrin
Some nice tips in there, keep em coming with the good pics WTG.
benny b
#354 Posted : 09 September 2013 19:42:50
nice work there claret looking very nice. benny b.
#355 Posted : 09 September 2013 22:45:52
Hi Claret, you are certainly being rewarded for the effort you are putting in.... she's coming on really nicely..... Cool Cool Will be waiting for your next instalment so keep posting... Cool Cool
claret
#356 Posted : 09 September 2013 23:00:26
Hi Alan, Benny B and Derek,
Many thanks for looking in and your kind. Comments.
Claret
Also working on:
SOTS.
finished:
007 Iconic DB5.
claret
#357 Posted : 10 September 2013 08:34:17
Hi,
More progress on the galley.
I had been let down by CMB and have still not received the diamond mesh after a month, so I used the stock mesh supplied with the model, but cut them into 10mm lengths. These lengths were turned through 45 degrees and cut to fit over the window opening without overlapping on the next mesh. This I think gave a more realistic 'leaded window' effect.
The sides were glued and clamped into place and sanded down once the glue had cured.
Claret
Also working on:
SOTS.
finished:
007 Iconic DB5.
claret
#358 Posted : 10 September 2013 08:39:27
Hi,
Glued the beak into place, and added the strips to it at the bow bulk head just to tidy and finish it off.
Also fitted the bottom side piece. This I found to be difficult, even after soaking the piece in hot water and clamping over night to but a curve into it.
Result below.
claret
Also working on:
SOTS.
finished:
007 Iconic DB5.
#359 Posted : 10 September 2013 08:40:48
Nice work ClaretBigGrin Kind regards Mike
claret
#360 Posted : 10 September 2013 08:45:09
Hi Mike,
thank you for your comment and looking in.
Claret
Also working on:
SOTS.
finished:
007 Iconic DB5.
This page was generated in 0.201 seconds.
