Carronade Problems Options
eoinkm
#1 Posted : 13 June 2010 18:47:52
Rank: Amateur Level 1
Hi all,
I seem to be having a problem fitting the brass wire provided through the pivot hole on the base of the barrel. The brass wire is too thick.
Is anyone else having this problem and how do you solve it?
Eoin
streaky
#2 Posted : 13 June 2010 21:03:44
Hi Eoin,
I simply milled mine out with a small circular abrasive bit. Careful boring with an appropriate drill bit would also work or perhaps a delicate circular needle file.
While I was giving it some attention, I also took the opportunity to tidy up the bracket and make it a little more delicate. It's far too clunky as it is IMO and could do with losing a fair bit of material.
HTH.,
Streaky
Jenny Wren
#3 Posted : 13 June 2010 21:04:31
Yes I had the same problem I just filed it down to size and that woeked a treat. Kay
Mike Turpin
#4 Posted : 13 June 2010 22:10:08
I had a good look at the carronade and decided that the trunnion assembly needed to be a lot closer to the bed of the carronade. You might like to look at Carronade Re-visited -- Leeds Build
Mike T
Capt Stedders
#5 Posted : 13 June 2010 23:27:53
As Mike says.
In fact, you may find it easier to scratch build a more accurate trunnion (Pivot and support) than fiddle around with the brass bits - if you do decide to go this route, I strongly suggest that you make two at the same time to ensure that both carronades match up.
I made mine from bits of spare styrene sheet and rod - but you could just as easily make the bits from spare bits of wood and some of that brass wire - just remove the lumpy square sectioned pivot part from the bottom of the barrel (it snaps off quite easily as it's only glued on) and file a shallow groove (using a round needle file or rifler)which will then sit on the pinion as shown in the above picture.
Another feature of the supplied carronade that may cause a raised eyebrow is the rear wheel arrangement - the wheels are a tad oversized and when fitted into the etched brass rail, lift the rear of the carronade higher than the front.
A simple solution would be to dispense with the brass part that holds the wheels and carefully glue the wheels into place using superglue - being careful to get the alignment right - they both face to the outside lengths of the carriage - not to the front (you won't even notice the absence of the brass bit when the build is complete anyway).
As a modeling exercise, the fiddling around with brass bits has a value - but as a part of the model itself.. (I'll leave you figure that one out).
Schnellboots on back burner
Tools.
john Ralph
#6 Posted : 15 June 2010 14:29:14
I have some watchmakers pin broaches (reamers) that will open holes out from nothing up to virtually. try watchmakers material dealers.
