Gun ports Options
Allan Brock
#1 Posted : 29 August 2013 13:41:05
I live in South Africa and we are only on issue 21. Can anyone help me with the gun port template, in issue 35 I think, because I prefer to build the ports as I go and not cut them later.BigGrin
KobusBeukes
#2 Posted : 29 August 2013 18:21:59
Hi Allan
Welcome to the forum!BigGrin I can not answer your question as I'm on issue 18 now but am sure that you'll receive a reply very soon!
Enjoy the buildCool
Kobus
Current Build
HMS Sovereign of the Seas - First Build
#3 Posted : 29 August 2013 19:28:40
BigGrin Hi Allan welcome to the forumCool
Marcel
#4 Posted : 30 August 2013 20:27:15
There is a Typo with the gunports location. Make double, triple sure about the locations.
Welcome the forum
Marcel
The Italian forum has all the info you want.
#5 Posted : 30 August 2013 20:44:06
hi allan,the gunports do not have a template as such, only very careful measuring AFTER some of the planking is done.it is fairly straight forward to do, but cutting out is never the best job to do anyway. just take your time and enjoy. k.BigGrin
vindicari
#6 Posted : 01 October 2013 21:05:20
I made a template from 1mm ply, after marking all the frames and decks on the outer hull I pinned two battens at the line of each deck. measured from each frame drew round the template sitting on the batten and then the fun starts with a scalpel. time consuming but worth it.
This page was generated in 0.190 seconds.
