Paint Suppliers Options
#1 Posted : 29 August 2013 09:39:47
I have been looking at paint options for my build. hear are some links I think are quite good.
http://www.phoenix-paints.co.uk
http://www.modelmates.co.uk
http://www.howesmodels.c...Product.php?ProdID=6785
If you have found others or have recommendations please share as i have yet to decide what paints I am buying.
#2 Posted : 29 August 2013 10:19:54
If your into metalics and airbrushing try this site.
http://www.snmstuff.co.uk/alclad-ii-lacquers/
#3 Posted : 29 August 2013 10:29:20
Railmatch and Phoenix are the most popular used by loco kit builders.
Dennis
#4 Posted : 30 August 2013 08:26:37
The main problem is not the paint but the primer. Since the base metal is mainly brass and even alloy then an etch primer is essential if the top coat is not to simply fall off. Matt/satin finishes are now quite popular in auto motive circles so your local auto spray shop will be able to provide matt black or whatever you decide plus etch primer. However that assumes your spraying, airbrush etc. If your limited to brush finishing then probably enamel paints and the suggested suppliers will be fine. A word of warning is that enamels because they depend upon oxygen take some time, even weeks to harden.
Finally please read the safety data sheets whatever you decide since many paints are hazardous and ventilation could be essential. I realise it's only a smallish model but safety first.
Dennis
#5 Posted : 30 August 2013 10:51:26
Hi Dennis thanks for the information no doubt helpful to many. You are spot on with preparation being the key. I am still looking at my options as I will be doing a combination of airbrush and brush due to doing some weathering!
#6 Posted : 07 September 2013 21:46:15
BigGrin Hi All
Humbrol have just introduced a new range of weathering powders that are aimed at loco buffs [well that's what was quoted in the railway mag i got] there are 8 in all and they recomend a spray of matt varnish from about 2 feet away to seal the powder. Note you will still need to use a good undercoat and top coat like Railmatch's weathered black before these are used. here's the link
http://www.humbrol.com/s...ers/weathering-powders/
Enjoy
#7 Posted : 07 September 2013 22:33:14
Nice find Cool
NMBROOK
#8 Posted : 07 September 2013 23:01:20
I use UPol etch primer available from halfords in an aerosol.One thincoat is all that is necessary so one can will probably do the whole model.As long as the items are fully degreased there won't be a problem.However on the soldered railings on my r/c boat build I did first blast with a badger abrasive gun to increase adhesion.This is mainly because the model will be subject to regular handling.
Kind Regards Nigel
This page was generated in 0.125 seconds.
