12 Pages «<56789>»
Kobus' SOTS Build - SA Options
KobusBeukes
#121 Posted : 28 August 2013 06:21:08
NMBROOK wrote:
Great work KobusCool it looks like you have a nice little production line going.
Kind Regards Nigel
Hi Nigel
Thanks for looking in. Yes, the production line works well!BigGrin
Kobus
Current Build
HMS Sovereign of the Seas - First Build
Marcel
#122 Posted : 28 August 2013 07:56:25
I have a big order for you of bamboo twisting and bending.BigGrin
It looks great. While you do mine, I'll go fishing.
KobusBeukes
#123 Posted : 28 August 2013 16:37:56
Hi Marcel
AnytimeBigGrin !!! Must say the steamer is working well and that is a big plus!BigGrin
Kobus
Current Build
Marcel
#124 Posted : 04 September 2013 00:31:26
I found that using a glass filled with boiling water makes a cheap former that works quick. I steam the plank in the kettle for 20 seconds and then bend it around the hot glass. The heat of the glass prevents the fast cooling of the steam in the bamboo.
KobusBeukes
#125 Posted : 10 September 2013 18:13:41
!! Update !!
After a nice week of whale watching in Hermanus, Western Cape SA, its back to work and building of the SOTS!
Done the first two planks at the bottom of the hull, the twisted pair, and happy with the outcome! LOL
The top four rows are also completed, now for the shaping of the fith row!Mellow
Kobus
Current Build
#126 Posted : 10 September 2013 18:27:23
BigGrin Nice work on the planking Kobus BigGrin Rgd Martyn
KobusBeukes
#127 Posted : 10 September 2013 19:36:27
Hi Martyn
Thanks very much for the nice encouragement!BigGrin
Kobus
Current Build
#128 Posted : 10 September 2013 23:06:03
Well done Kobus, nice and neat planking....Cool Cool
KobusBeukes
#129 Posted : 11 September 2013 06:04:28
Hi Alan
Thanks for looking in and for the nice words. LOL Much appreciated!
Kobus
Current Build
claret
#130 Posted : 11 September 2013 08:44:32
Hi Kobus,
Planking coming Long nicely.
Claret
Also working on:
SOTS.
Waiting in the wings:
finished:
007 Iconic DB5.
Marcel
#131 Posted : 11 September 2013 11:13:42
Welcome back, Kobus. The whales are a pretty sight to view. So is your planking, well done. I found by removing the laser ash, the glue bonds stronger with the hull.
Keep filling those empty spaces..
Marcel
KobusBeukes
#132 Posted : 11 September 2013 17:27:00
Hi Claret and Marcel
Thanks for looking in. Thanks for the nice comments and the encouragement, much appreciated!
Marcel, the whales were a sight to believe! They are enourmous!
Kobus
Current Build
KobusBeukes
#133 Posted : 17 September 2013 05:58:26
Hi all
Received my next four issues, 20 to 23, with the first binder!LOL
Can now continue with the planking of the hull, looking forward to it!BigGrin
Kobus
Current Build
KobusBeukes
#134 Posted : 19 September 2013 19:15:10
!! Update !!
Hi all
At last something to report on again!
Completed the first ten (10) rows of the planking and cut it flush at the stern. Happy with the outcome!LOL
Used my trusted Dremel with a cut-off wheel 420 to cut off the access and then a sanding barrel to sand down till flush! Must say, I enjoyed the Dremel with the flexable shaft, makes life so much easier!
Kobus
Current Build
#135 Posted : 19 September 2013 20:51:50
Very neat and tidy Kobus, very well done.. Cool Cool .. Your patience and research have definitely paid off....Cool Cool
KobusBeukes
#136 Posted : 19 September 2013 21:20:06
Whilst busy removing the excess glue, which I used to glue the bamboo planks together, with a Stanley knife blade I noticed that I'm actually shaving the planks even!
A few moves over the planks, with the blade perpendicular to the planks and at a slight angle across the planks tend to do a fine job without much of an effort!
Kobus
Current Build
KobusBeukes
#137 Posted : 19 September 2013 21:24:40
Hi Alan
Thanks for looking in and the nice comments!Love
For a Master like yourself to still look in at other novice builds and providing encouragement and advice is much appreciated!ThumpUp
Highly appreciated!
Kobus
Current Build
NMBROOK
#138 Posted : 19 September 2013 21:54:11
Very neat planking KobusCool Cool Using the blade like that is the same as using a cabinet scraper.I use those regularly,you get a flat surface instead of rounding it like you can with sanding.The stanley blade is a good way of smoothing areas in corners where you can't get in with sandpaper.
Kind Regards Nigel
KobusBeukes
#139 Posted : 20 September 2013 06:01:42
Hi Nigel
Thanks for looking in and for the nice comment!BigGrin
Kobus
Current Build
#140 Posted : 20 September 2013 07:34:09
BigGrin Nice work Kobus looking bril rgd MartynBigGrin
Guest (5)
12 Pages «<56789>»
This page was generated in 0.159 seconds.
