19 Pages 123>»
Tom Options
tom.ganc
#1 Posted : 12 April 2010 22:56:45
Hi there
I've already purchased Issue #1 and started subscribing from Issue #2.
No #2 and #3 should arrive in few days so I can't wait.
Still need to get paint set and few bits but I have plenty of time (as we all do :) )
I post some pictures when I start my build properly.
Tom
Zeptrader
#2 Posted : 12 April 2010 23:06:18
Good luck Tom
Capt Stedders
#3 Posted : 13 April 2010 00:16:38
Welcome aboard.
It's a fun and friendly ship.
Schnellboots on back burner
Tools.
dtgray
#4 Posted : 14 April 2010 14:59:48
Good luck with your build Tom, I look forward to your pics Smile
David
Horatio's Eyepatch
#5 Posted : 14 April 2010 15:26:22
Good luck Tom - i'm waiting for the subscription to start too. I look forward to sharing your experiences!!
tom.ganc
#6 Posted : 23 April 2010 11:47:32
Hi again
Some more stuff just arrived today (some paint, fine chain, glue, micro drill bits, files set, etc)
I'm hoping to get cracking this weekend.
I want to add more detail to the 12-pounder, anchor and carronade aswell.
I'll post up some pics when I've done something BigGrin
Tom
tom.ganc
#7 Posted : 08 May 2010 03:29:26
Hi
I've starter my 12-pounder for now. First thing I did was filling groves on carriage because they were too deep, then I added some more detail.
I'm going to paint it later when I finish my carronade.
Take a look
Macmedal
#8 Posted : 08 May 2010 09:44:18
Looking good look forward to seeing the finished item.
jonny7england
#9 Posted : 08 May 2010 11:05:25
Mice piece of work ThumpUp
#10 Posted : 09 May 2010 00:27:54
really good i like a lotCool
where did you get the chain?
tom.ganc
#11 Posted : 09 May 2010 00:35:25
Hi
Chain is from Cornwall Model Boats (part -
5627/03 Brass Chain 1mm Links)
Hope it helped
Tom
tom.ganc
#12 Posted : 15 June 2010 00:50:56
Hi again.
I've had a little break in building but I'm back now. My canon and carronade are not painted yet because I don't see much point in painting one canon at time - I'll paint at least few of them at once.
The time has come to build the Launch. It is my forst wooden build so I'm bit worried about my planking skills but check my results so far.
I'm going for painted finish so even if planking isn't 100% right I should be ok :)
#13 Posted : 15 June 2010 11:52:11
Hi Tom, looking good there! I see that you have cut your planks down....are they going on easier than expected???
tom.ganc
#14 Posted : 15 June 2010 12:19:51
Hi Captn. Yes, I cut them down and I need to tell you that it is much easier now. I know that you end up with twice as many planks but shaping them is easier. I hope to get the planking done tonight and post some more pics.
Tom
#15 Posted : 15 June 2010 12:44:07
Tom
Hi tom, i had to re-order issue 6 after breaking one of the ribs. This meant that i could have a practice go at the planking, and was finding it a real b****. I think i'll go down this route too. My other problem was that i don't think i chamfered the bow enough....it looked like it had a step in itLaugh
tf5600
#16 Posted : 15 June 2010 17:55:15
Looking good Tom, have not started my planking yet, got to be in the mood
Ferret
Capt Stedders
#17 Posted : 15 June 2010 20:50:16
So far, so good. Cool
Using half width planking does seem to make things easier when it came to bending the planks - it just takes twice as long and uses more glue. The only thing trickier that I found with doing it that way was shaping the ends to fit - being thinner made them more prone to flexing when I got the abrasive paper out.
It simply requires a little more patience - but the results are certainly worth the extra effort.
Tools.
jonny7england
#18 Posted : 15 June 2010 21:04:34
Looking good Tom, but are the planks easy to cut straight without splintering? Just finished putting the ribs on my launch today without breaking anything so far?? I will chamfer the ribs tomorrow before attempting the planking...Unsure
tom.ganc
#19 Posted : 15 June 2010 23:54:15
Hi Jonny
Cutting them planks wasn't difficult - just make sure you have sharp blade.
Capt Stedders - you are right. Planking is easier but takes more time. But we have loads of time aren't we ? :)
jonny7england
#20 Posted : 16 June 2010 11:06:08
Tom...did you use super glue on your planking or good old wood glue? Thanks mate...ThumpUp
19 Pages 123>»
