bamboo planks and advise. Options
mark 2
#1 Posted : 25 August 2013 13:05:05
Hi Everyone BigGrin .
I am after some bamboo planks after making a mistake so does anyone have any that i could buy from them please also i have just bought an electric plank bender and wondered what the process of using it was ie:- dampen planks or not.
Thanks for any help on these two questions would be much appreciated.
Best regards all.
benny b
#2 Posted : 25 August 2013 15:30:41
hi mark pm your address and I will send you some I,ve plenty free of charge benny
Marcel
#3 Posted : 25 August 2013 15:49:04
Bamboo
You can back order from your news agent. Its expensive if you need alot of strips. Mr T notes that you would not find any quality bamboo on the market.
Electric Bender
If using an electric bender, its better to soak the strips before bending it. When it becomes dry, it can easily burn the wood. The thinner the strips, the quiker they dry out and are more likely to burn.
Its wise to bend the left and rigt hand side simutaneously to get a mirror image. Some people use ammonia to soak the planks as it interact with the chemicals in the wood (too smellyBlushing )
Sovereign of the Seas
Captain David
#4 Posted : 25 August 2013 17:11:59
Hi Mark.
You don't say how big a mistake you have made!
You should get far more bamboo supplied than you need.
mark 2
#5 Posted : 25 August 2013 18:21:48
Hi Everyone.
Thanks to Benny, Marcel and Captain David.
Thanks Marcel for the advice on the plank bender BigGrin .
This is one of the reasons what i Love about this website is that there are so many great people on here.
Hi Mr T please could you look into puting a section in for spare parts as i think it would benefit everyone.
Thanks for such a great response.
Best regards.
#6 Posted : 25 August 2013 23:17:00
Hi Mark, another thing to look out for on the bamboo.... take the strip and bend it a little in both directions in your hands, you will find it bends easier one way than the other..... the easier side is the way you should bend your planks..... BigGrin Blink BigGrin .. I simply used steam from a kettle first identifying the easier way the plank would bend.... Cool Cool
Hope it helps...
mark 2
#7 Posted : 26 August 2013 08:11:40
Hi Alan.
Thanks for the great advise i will certainly try that BigGrin .
Best regards.
