UNgluing!!! Options
#1 Posted : 14 June 2010 17:47:46
Hi all,
Due to warpage i need to unglue my keel. Any ideas as to the best way to go about this? Confused
Would heating it up under wifey's iron do the job, d'ya think???
Zeptrader
#2 Posted : 14 June 2010 18:14:29
How bad is it and what part? to be honest you can get away with a lot with filler blocks once we start glueing the frames.
#3 Posted : 14 June 2010 19:26:51
Best way to unglue is to warm up with an iron, which will soften the glue. Trust me I had to through warpage.
Hope that helps..
Chris...
#4 Posted : 14 June 2010 19:34:39
Hi Colin, It is noticable, and warped on both planes, ie horizontal & vertical.Cursing I think that seeing as i have now received my replacement (thanks Customer Care!)i might as well use them. I would rather do that than rue the decision later, and it's always better to have the keel straight now than wish it was later.
Chris, that was what i thought, but good to have a second opinion.
Zeptrader
#5 Posted : 14 June 2010 20:25:54
Glad you got it sorted.
#6 Posted : 15 June 2010 01:13:06
Assuming you used PVA, Colin is spot on. Warm it with an iron, and winkle a knife blade underneath - it should come off without damaging either part.
#7 Posted : 15 June 2010 11:26:39
Hi Mark,
That's exactly what i did, and it came apart a treat BigGrin New Bow Keel fitted and looking STRAIGHT!!! If i hadn't done it i would have always known it was there and always have worried about it. As Colin has said, i could have tried to pack it out, but as we are paying good bucks for this model, it needs to be right (or as right as MY skills can get it!) LOL Laugh LOL
benny
#8 Posted : 28 June 2010 21:21:05
or you can run the hot tap and place your glued part under it and gently wiggle it
cheers benny
This page was generated in 0.248 seconds.
