HMS VICTORY Options
chrisN257752
#1 Posted : 14 June 2010 17:10:26
HELLO MY FELLOW "MODEL MAKERS" I AM STILL HAVING TROUBLE WITH THE KEEL, I HAVE A SLIGHT CURVE BETWEEN 16 AND 21 WHERE THE SLOTS ARE IS THIS GOING TO BE A PROBLEM GOING INTO THE BUILD OR WILL I GET AWAY WITH IT WHEN WE GLUE ALL THE RIBS IN THE SLOTS THANKS FOR YOUR OTHER ADVICE WILL WAIT FOR RESPONSE.
THANKS CHRIS
#2 Posted : 14 June 2010 17:18:00
Hi Chris, and welcome.
If it was me, i would ring customer services and tell them your keel is warped and ask them to send out a replacement. It's what i did with mine, however i am still waiting for that issue to arrive!!!Mad
EDIT: part waiting for me when i got home today. Thanx
Zeptrader
#3 Posted : 14 June 2010 18:12:46
What part of the Keel, 1, 2 or 3?
chrisN257752
#4 Posted : 14 June 2010 18:59:21
part2 between 16 and 21
Zeptrader
#5 Posted : 14 June 2010 20:24:02
If its not too much then have a look at my build (the last post) I was briging up the idea for me that is to use filler blocks to help rid the keel of this issue, only if its not too bad.
tf5600
#6 Posted : 14 June 2010 22:52:04
Chris,
If you don't get no joy from customer services, i have a spare as i ordered pt 3 again to have another go at the carronade, it is the keel section 16 to 21 and its flat, your welcome to it,
ferret
chrisN257752
#7 Posted : 19 June 2010 19:44:47
THANKYOU TO ALL THAT HELP ME WITH THE WARPED PIECE AND NOT FLAT
I HAVE NOW GOT IT SORTED SO AM LOOKING FORWARD TO THE BUILD
HOPE YOU ALL HAVE A GOOD BUILD
CHRISBigGrin BigGrin Laugh
This page was generated in 0.253 seconds.
