Degaussing cable Options
dbartonjr
#1 Posted : 16 August 2013 17:51:10
I have been reviewing Mr T's and Andy's build diaries and I see that they replaced the supplied wire with 1 mm strips. I have been trying to find where to purchase this in the UK. Can anyone help me?
Thanks again for all your support.
Current Builds: Yamato
On the Bench: Akagi, USS Missouri
#2 Posted : 16 August 2013 18:36:40
BigGrin Hi Db
What your after is and what we both used was 'Evergreen Scale Models' StripStyrene .020x.040 inch [0.5 x 1.0 mm]size its available at Hobbystore branches or from online model shops you will need about 40 strips or 4 packs to do the Yam with some left over. Hope this helps
Andy Cool
dbartonjr
#3 Posted : 23 August 2013 18:00:07
Andy,
Thanks for the info. Just a quick question, I assume you are talking about it being a rectangle, do you have a part number by any chance. All I can find are Styrene Rods, circular.
All help appreciated.
Thanks again,
Dan
#4 Posted : 23 August 2013 18:28:33
Hi Dan this may help
http://www.cornwallmodel...catalog/plasticard.html
#5 Posted : 23 August 2013 21:07:47
BigGrin Hi Dan
Item no 122 for the strip and for the brackets I used No 10 staples bent over a 1mm metal sheet to get the shape
