6 Pages <1234>»
Build Diary of Amati 1/200 Bismarck Options
B Johnson
#21 Posted : 16 August 2013 20:44:47
Does anyone know what these marks are?
The Hatchette build guide shows the three camouflage paint schemes, on the version 1 + 2 there are black marks on the hull below the 'c' turret (see the photo below, indicated by the red circles) at first i thought it was just a print error but i found a couple of photos from the Ship Craft Bismarck and Tirpitz book that back the marks up.
Bismarck at Grimstadfjord Norway
The marks just visible due to the bad scan, this was taken after the hit from the Prince of Wales, photos scanned from Ship Craft Bismarck and Tirpitz Steve Backer
Current Builds: Amati 1/200 Bismarck, Airfoil 1/600 HMS Nelson
To Build: Amati 1/200 HMS Hood, Amati 1/250 Titanic, Artesania Latina 1/48 HMS Surprise, Artesania Latina 1/50 Scottish Maid, DeAgostini 1/84 Sovereign of the Seas
#22 Posted : 16 August 2013 21:23:41
Interesting. my first reaction was a paint platform but that would not be out while at see. I have the same pic in anatomy of the ship there are some swing booms in that location and there is also a small hatch but there is nothing on the plans of that shape. It could be light casting a shadow so if the swing boom is closed you would have two shapes. I also consulted Dr Ballards discovery of the Bismarck nothing in there so I consulted my reference pics. there are several picks that do not show this. so what ever it is is not part of the hull so is detachable. I then found a pick as she was being worked up that showed some form of cage in that location slung over the side of the hull at deck level.
You can see in this link the hatch but nothing else and no black paint
http://www.bismarck-clas...bismportaftsection.html
You can see the cage in this shot (bottom pic)
http://www.bismarck-clas...ery/gallbismcommis.html
in this link you can clearly see something is there but i don't think it is paint in one areal shot it is a lot darker than the black strips
http://www.bismarck-clas...ery/gallbismrhein2.html
In this link there is a pic of Prinz Eugen with a similar mark in a similar place
http://www.bismarck-clas...ery/gallbismrhein3.html
I have also seen the same mark on the sister ship Tirpitz.
so in conclusion... I haven't the faintest Blushing BUT fairly sure it is not paint so is a mistake on your plans and also fairly sure what ever it is is removable so from a model point of view you can ignore it.
B Johnson
#23 Posted : 17 August 2013 11:36:27
Fairly storming on with this build Ben, looking great so keep up the good work.... Cool Cool
Thanks, yeah I started this a couple of years ago and thats why the pics are coming thick and fast
B Johnson
#24 Posted : 17 August 2013 11:53:04
Its a strange one, there is a modern German corvette that has exhausts just above the water line creating black smoke marks but theres nothing to say Bismarck had anything like this plus the marks have quite square edges on the Bismarck so I don't think smoke could have caused this. It could have been caused by something rubbing up against the ship?
B Johnson
#25 Posted : 17 August 2013 12:10:39
The fwd structure has now been clad in photo etch, gaps filled and sanded off. I have glued together the various plastic parts and started to build the four main gun casings.
I have improved the kit ventilation louvers by adding strip plastic
I have also started to work on the aft mast at this point
#26 Posted : 17 August 2013 12:17:55
Wow your steaming ahead with this. Question does the funnel come with the lift or is it excluded?
B Johnson
#27 Posted : 17 August 2013 17:27:52
Yeah the model is quite advanced now, I did start it a couple of years ago but only found out about the forum recently.
There is a bit of photo etch that comes with the kit to imitate the lift but it was way too thin so I have scratch built my own. See the photos from the assembly guide
#28 Posted : 17 August 2013 19:13:04
Nice first kit I have seen with this on.
#29 Posted : 17 August 2013 19:29:52
BigGrin The etch is certainly setting her off, nice workCool
#30 Posted : 17 August 2013 22:31:30
Lovely work Ben, certainly enjoying following your progress with this one.... Drool Drool
B Johnson
#31 Posted : 24 August 2013 19:02:44
Now i started work on the main and secondary gun casings. They were clad in photo etch, however the fit was really bad and I found that there were many overlaps that would need to be sanded back and gaps to be filled. I also started to build the frame work for the funnel hangars and one of the ships radars.
B Johnson
#32 Posted : 25 August 2013 11:27:46
More work on the side hangars, they have had a skin of ply applied, this was primed and sanded back to give a smooth finish ready for the etch to be applied, some basic work done to the funnel, this was glued together, gaps filled and sanded. I added a cage to the top of the funnel using fuse wire. I also drilled holes into the exhaust pipes around the cap of the funnel as these came solid with the kit part. However i'm not too pleased with the outcome as some are off center. I have also made some progress on the hull.
As you can see from this photo there is an edge that runs around the whole ship, however the deck supplied with the kit comes to the very edge of the ship, i have tried sanding back the deck to produce an edge but this has not worked because i'm starting to lose the edge detail of the deck. So i have added plastic strip around the hull to give me the edge.
The instructions were unclear on how this edge should look so i rounded it off, but i think this was wrong and it should be flat along the deck so i have added a strip of wood which will be sanded back and the top filled to give me the flat surface.
The first coat of primer applied, I used the Humbrol 150ml primer at a cost of £5 a can, this can lasted for the one side of the hull! I needed to find an alternative which would be the Halfords 500ml primer.
#33 Posted : 25 August 2013 12:18:04
BigGrin Hi There
She is certainly starting to look the part now. The lip you mention around the deck edge looks to me like its attatched to the hull by a piece of angle iron and the upper part you can see in the picture riveted to this metal.
I generally use 2 types of undercoat the Halfords yellow filler primer and one I get from a local pound type shop called Canbrush grey primer this gives a finish like plasticote but is way cheaper. Hope this helps
B Johnson
#34 Posted : 25 August 2013 17:39:04
arpurchase wrote:
BigGrin Hi There
Thanks Andy,
Theres so many little extras you see in photos and want to add them to the model to make it as realistic as possible, but where does it end? LOL I hope I have re-created this edge to something of how it looked, you can see how this turned out when i get the photos up.
Yeah I have started to use cheaper primers, it was costing a fortune at £7 a can, I found one called simoniz for just over £3 a can, and it gives a good coat.
Ben
B Johnson
#35 Posted : 26 August 2013 11:14:05
The hull has now had a complete coat of primer and i'm able to see where there is work needed (and a lot is needed!) and so begins the first round of filling and sanding.
Using the templates provided I have drilled the port holes along the hull, I have also added the prop shaft exits and supports.
More work has been made on the fwd structure, mainly the bridge section with photo etch added, there were also various platforms added to this. I have added the railings around the aft range finder towers and removed the original foot holds because they were too thick, they have been replaced with a finer fuse wire shaped accordingly.
There are also a couple of photos of the overall model at that time of the build.
NB the gun barrels have not been glued in place yet, plus they are upside down because they wouldn't stay in place the other way up LOL
B Johnson
#36 Posted : 05 November 2013 21:25:37
After some time away and other things happening I have had a chance to start work on the model again.
To address the step between the platforms and deck below the funnel, I used some strip wood glued in place and sanded down, so when painted it gives the impression of a continuous deck
The superstructure has also had its first coat of primer, from this i can see where work is needed, either sanding back of metal parts or filling. However I think the ship is starting to look good at this early stage, the paint has really brought out the detail in the etch parts.
#37 Posted : 05 November 2013 21:50:14
Looking good Cool
Virtue86
#38 Posted : 06 November 2013 10:56:05
looks great ben, will be looking forward to seeing a few more pictures. This log will be a good reference for me when i come to start mine once the hood is finished. That might be some time though.
Cheers
Peter
[b]Built:1:250 Titanic
Foz
#39 Posted : 06 November 2013 13:40:21
Looking really smart, look forward to your progress.
Foz
B Johnson
#40 Posted : 06 November 2013 20:12:19
Thanks for the comments BigGrin
6 Pages <1234>»
This page was generated in 0.703 seconds.
