Stand Options
neon
#1 Posted : 14 August 2013 13:20:02
hi folks.
still working away at the dreaded planking. just a quick question. does anyone know if a stand for the model is going to be supplied. I realize in an earlier issue you could make one but I did not take advantage of it. I was just wondering because when I go to complete the outer planking on the hull I would require a stand so it does not get damaged.
if anyone knows the answer, much appreciated.
#2 Posted : 14 August 2013 13:36:54
no stand that I'm aware of, best make your own.I do recall that there might be a display stand at the end of the build for about £20.00.
neon
#3 Posted : 14 August 2013 22:37:55
Thanks Karl.
Jesus after building a model as expensive and as good as this you would think a stand would be part of the job.
Anyway thanks karl.
This page was generated in 0.083 seconds.
