HMS VICTORY Options
chrisN257752
#1 Posted : 13 June 2010 11:50:49
Cursing Hi All
I am new to this model building and i am having trouble with the extension of
internal "KEEL" Part2 no 16 to 21 i can't seem to get it straight and flat would be great if someone would help me out,
thanks chris
Allan
#2 Posted : 13 June 2010 12:57:50
chrisN257752 wrote:
Cursing Hi All
thanks chris
try laying it on a true flat surface ie worktop or a flat piece of marble and put some weight on it and leave for the glue to dry
hope this helps
Allan
Capt Stedders
#3 Posted : 13 June 2010 13:28:26
There was a handy topic posted a while back, covering the method to straighten out any warped bits (if it was badly warped when you received it, contact customer services for a replacement).
The basics of this topic were steaming the part (watch your hands - or better still, use tongs), and following the advice given above in Allan's post. Be prepared to be patient though - the longer you leave the parts under a nice heavy bit of weight, the less likely they will be to spring back out of shape.
Schnellboots on back burner
Tools.
This page was generated in 0.155 seconds.
