Well done Kobus, looks briliant. Rgds, Hans "It's okay to make mistakes. mistakes are our teachers - they help us to to learn, even if it is painfully" Current Build: Endeavour Cross section,D51 Completed: HMS Victory Under the bench: Endeavour x 2,Sovereign of the Seas, Akagi and The Black Pearl!HMS Victory Cross Section
Joined: 27/02/2013 Posts: 228 Points: 664 Location: Bursledon
Good practice with the staining of the bowsprit, Kobus - but it will not be seen in the final build.
Joined: 23/04/2013 Posts: 287 Points: 859 Location: Hartbeespoort, NW, South Africa
Captain David wrote:Good practice with the staining of the bowsprit, Kobus - but it will not be seen in the final build.
Hi Catain David I saw Alan covering his bow spirit with walnut sheets and decided, as I have 3.2 mm walnut available, that I would cut mine out of solid walnut. I'm in between deliveries so have some spare time available to experiment. I didn't know that it would not be visible in the final build, but thanks for the info! Regards Kobus
Current Build HMS Sovereign of the Seas - First Build
Hans wrote:Well done Kobus, looks briliant. Thanks for the nice feedback Hans! Regards Kobus
Nicely done Kobus..  .. The reason I covered mine with walnut sheet was because I covered the keel to match the hull so just continued all the way rather than just simply cut it where the black starts, neater that way.....  .. I am probably going to paint it black anyways.....  .. Regards Alan
Gandale wrote:Nicely done Kobus..  .. The reason I covered mine with walnut sheet was because I covered the keel to match the hull so just continued all the way rather than just simply cut it where the black starts, neater that way.....  .. I am probably going to paint it black anyways.....  .. Regards Alan Hi Alan Thanks for the nice words and the advice  , much appreciated! Regards Kobus
Joined: 16/06/2013 Posts: 284 Points: 859 Location: Cape Town, South Africa
Neat lines on your Launch.  I am thinking of double plank the launch in Sapele. As a Newbie, I made a mess of the first try.  Its resting in a safe place to be commence on a much later date. Meanwhile am I focusing on the actual boat. I want to do all the smaller builds at once. My friend around the corner of me is also building the SOTS. I am fortunate to share consumables with him. I am at issue 19 now. I bought extra issues for the sake of stocking wood supplies. I want to buy extra figurines when they arrive here. According to the Italian forum, SOTS do have great figurines. I want to salvage some Victory figurines for my collection. If you came across them, PM me. Regard Marcel "Rather try and fail than had failed to try".Sovereign of the Seas Model Space forum: Marcel's build
Hi Marcel Thanks for the nice comments on the launch! Much is hiden behind the woodfiller and paint! As I was going for the painted finish on the launch I use some woodfiller to smooth out the planking. Must say I'm happy with the outcome! Regards Kobus
 Nice work on the launch Kobus  Rgd Martyn Building ? Completed. Soliei Royal . Sovereign of the Seas . Virginia . Scotland . San Felipe . Corel vasa , Santisima Trinadad X section , Vasa Next Build ? When sailors have good wine, They think themselves in heaven for the time. John Baltharpe
Martyn Ingram wrote: Nice work on the launch Kobus  Rgd Martyn Hi Martyn Thanks for the nice words! Much appreciated! Regards Kobus
!!!  Update  !!! Received my next four issues (16 - 19) today,  with my mitre set and mini clamps!  Thanks Jacklin! Started with the stern planking and it came out nicely (will post some photos tomorrow)! Must say, expected the bamboo to be much harder to work with and more knots in, unless I got a better bunch! Regards Kobus
KobusBeukes wrote:!!!  Update  !!! Received my next four issues (16 - 19) today,  with my mitre set and mini clamps!  Thanks Jacklin! Started with the stern planking and it came out nicely (will post some photos tomorrow)! Must say, expected the bamboo to be much harder to work with and more knots in, unless I got a better bunch! Regards Hi Kobus, at least with these 4 issues you'll be kept busy for a while.... look forward to seeing your progress... Regards Alan
Hi Alan Thanks for the encouragement, will post some pics tonight! Regards Kobus
Photo Update! The stern finished planking!   Regards Kobus
Hi Kobus, Looking good, just one bit of advice (from my view). Your fifth plank down on the stern is bending round the stern post. I don`t think it needs removing, just a sharp knife to cut a small notch around the false keel section. This should make your second planking much easier around that area. Keep up the good work. regards delboy271155 (Derek) COME BACK GUY FAWKES "YOUR COUNTRY NEEDS YOU"
Yes I agree probably just needs a 1/2 mm slither removing “Whenever you find yourself on the side of the majority, it is time to pause and reflect.” -Mark Twain
delboy271155 wrote:Hi Kobus, Looking good, just one bit of advice (from my view). Your fifth plank down on the stern is bending round the stern post. I don`t think it needs removing, just a sharp knife to cut a small notch around the false keel section. This should make your second planking much easier around that area. Keep up the good work. regards delboy271155 (Derek) Hi Derek and Jase I've noticed the bend and thought I would sand it down to the other planks, but must agree if I cut a small notch around the false keel it would work much easier! Thanks fot the advice, much appreciated! Regards Kobus
Well done Kobus, your build is coming on smooth. Issue 20 is on the shelves at CNA. Grab an extra issue for the wood supply. Its cheaper than to order online. I admit that the first row at the bow is time consuming. I keep splitting the ends and have to start over. I noticed that some of the pins supplied, are blunt or croocked. The deck line take al lot of mini clamps and patience. I only recieved my mitre set. Hope to recieve the clamps with my next batch. "Rather try and fail than had failed to try".Sovereign of the Seas Model Space forum: Marcel's build
Nicely done Kobus, have to agree with Derek though, cut a small notch in that 5th plank to get a better fit around the false stern post... I think if you try to sand it down as you suggest then you may find you will end up sanding through the bamboo strip....  .. Nice work though, well done..... Regards Alan
Marcel wrote:Well done Kobus, your build is coming on smooth. Issue 20 is on the shelves at CNA. Grab an extra issue for the wood supply. Its cheaper than to order online. I admit that the first row at the bow is time consuming. I keep splitting the ends and have to start over. I noticed that some of the pins supplied, are blunt or croocked. The deck line take al lot of mini clamps and patience. I only recieved my mitre set. Hope to recieve the clamps with my next batch. Hi Marcel Thanks for the nice comments! I've already got myself a copy of issue 20 as a spare. I've used a Dremel fitted with a flexible shaft and a 0.5 mm drill bit and predrill the bamboo. It worked like a charm! Regards Kobus
Guest (5)
