 Rank: Pro  Groups: Registered
Joined: 24/01/2011 Posts: 206 Points: 614 Location: halifax
Could someone tell me if the 2 yard slings provided with issue 80 are the right size because comparing them to tge drawing they are much smaller ... Thanks cal cal attached the following image(s):
hi cal, looks alright to me,don't forget that ,that is a top view,so the overhang does not show on that drawing, k. Current builds: SotS, USS Consitution, San Felipe, D51 loco, HMS Surprise, RB7, Arab Dhow, Jotika HMS Victory Completed builds: HMS Pickel, Thermopylae, Mississipi river boat, Mary Rose, Cutty Sark, San Francisco II, HMS Victory x5, Titanic Lifeboat, Panart HMS Victory Launch, Hachette Titanic, Virginia Schooner, Endeavour Longboat. http://www.model-space.com/gb/
I think they are a bit small do you have some larger ones?. the pale rectangle is the footprint of the part the extending black line is the top of the part representing the overhang - or at least that is how I have understood it, just like a technical drawing view. I just did the main mast spar today and my part fitted to the plan. “Whenever you find yourself on the side of the majority, it is time to pause and reflect.” -Mark Twain
The rest have fitted the drawings .... what do they actually do and will it matter uf they are a bit smaller
I think they are used for fitting them to the mast. can you not fabricate replacements from some scrap? “Whenever you find yourself on the side of the majority, it is time to pause and reflect.” -Mark Twain
Sound's like a plan ....Thanks jase and Karl
