Top mast studding question Options
#1 Posted : 10 August 2013 12:21:29
some help please....
Issues 65 I am making the main mast yards both the instructions and the official build state ' taper two of the 3mm dowels'
I appear to have 5 3mm fowls all of which are long enough to make two booms.
my question is what length is the dowel other people have used or identified for use? I don't want to use the wrong one!!
#2 Posted : 10 August 2013 13:48:24
hi jase, I wouldn't worry too much, the yard booms are pretty much the same as each other,very little difference in them. so as not to cut one and not be able to cutanother,meaning do not leave too much waste,I had pieces left over after doing them all, you do get enough.3mm.dowel anyway. k.
#3 Posted : 10 August 2013 13:58:56
Thanks Karl that puts my mind at rest Cool
