Tilling the rudder Options
Glen
#1 Posted : 06 August 2013 14:43:32
Hi all,
Can anyone point me in the right direction for copper tilling the Rudder please, I have looked on the official build but I can't find it.
Thank' all,
GlenBigGrin
Roger the Cabin Boy
#2 Posted : 06 August 2013 20:33:26
Tomik's official build did not include tiling. It is a bit tricky but use the same process that you use for the hull. I painted mine Copper first then tiled from the bottom up. the little cut out sections for the hinges i left untiled but copper painted.
Just take your time and plan your attack Blink
Glen
#3 Posted : 07 August 2013 13:09:27
Thanks Jase ,so the edge where the hinges go, that's the rounded part that fit into the pintles, there is no need to tile that just paint copperConfused
Roger the Cabin Boy
#4 Posted : 07 August 2013 13:34:22
I did tile the rounded edge just left the gaps where the hing pin sits. another dificult part is the two little steps on the profile. but if you look at the real ship this is not tiled it is coverd in tar, so you could paint that plack and leve it. I will try and get a photo of mine on this thread tonight.
Glen
#5 Posted : 07 August 2013 14:53:29
Okay Jase thanks for that.
Roger the Cabin Boy
#6 Posted : 07 August 2013 21:10:30
I hope you can make out the area I have not tiled
Glen
#7 Posted : 08 August 2013 12:33:12
Thanks Jase all clear I can see how to do it now.
GlenLOL
Roger the Cabin Boy
