6 Pages <1234>»
How far along are u with your build? Options
rowdy85
#21 Posted : 04 August 2013 13:26:09
It comes in parts. We are at least 12 months away from that stage though. Issues 64-69 or 70?
64 Crankcase
65 Crankshaft
66 Piston and Liner/sleeve
67 Cooling Head
68 Pull start back plate and shaft ect
69 Pull starter?
70 ?
Nightrider
#22 Posted : 15 August 2013 16:18:16
So have you put anything else together lately?
Some photos would be rad..
rowdy85
#23 Posted : 19 August 2013 03:21:35
I have got around to putting my bits from July together yet. I'll wait till my August parts arrive. Should be any day now BigGrin
Simon Pilbeam
#24 Posted : 21 August 2013 12:33:56
Rank: Beginner Level 3
hey all,
been busy with work and have managed dribs and drabs.
also designing and printing my own decals. heres some snaps.
there is a 3rd but that will remain in pieces.
each car will be in Webber Vettel livery.
my german connection will have issue 75 by months end for me.
got pics up on my decal post. sorry brain fade tonight.
S
Wadeo
#25 Posted : 23 August 2013 11:01:04
Kind of funny this build, i forget about it and bam another delivery lol.
skyfire
#26 Posted : 23 August 2013 13:10:58
Publisher Medal: Featured Build of the MonthActive Service Medal: 500 post active service MedalBuild-Diary Medal: Build-Diary Medal of HonourRed Medal: Red Medal
Bought issue 23 this week from the newsagent, but stuck as still waiting for the blasted suppliers to deliver the missing issues, 10 and 11!!!
rowdy85
#27 Posted : 23 August 2013 16:24:38
I put together issues 10 to 18 tonight. Diag know how to spread things out.Cursing
Nightrider
#28 Posted : 29 August 2013 02:17:37
Got my issues 11-15 this week...
They are all stashed away waiting to be built
Dam only 15% through it.
Andreas
#29 Posted : 04 September 2013 20:37:42
Groups: registriert
Hi dudsy13
Too answer your question , too complete the engine you get 13 issues With engine Parts which you must Put together yourself. The engine starts With issue number 64 and ends with issue 77. Every Part you Put together is very nice explained. Today whe have got issue 75 here in germany,that means our engine is nearly finished. The engine has got a weight from 500gr. I hope i could help a little bit with Information about the engine
Wish you the best
Greetings Form Germany
Forum Support Team
rowdy85
#30 Posted : 05 September 2013 02:14:36
Thanks Andreas. Do those issues include the flywheel, clutch, clutchbell and pinion gear?
Andreas
#31 Posted : 05 September 2013 17:47:10
Groups: registriert
Hi rowdy85
Yes those issues includes every Part you need too complete your engine .
Forum Support Team
Andreas
#32 Posted : 05 September 2013 18:30:42
Groups: registriert
64 Crankcase
65 Crankshaft
67 Cooling Head
69 Pull starter?
70 ?
70 carburator
71 glow plug
72 second back tyre
73 a Tool you need too put together your pinion and flywheel
74 flywheel
75 clutch
76 pinion
77 exhaust With pipe
Now your engine is complete
Best wishes from germany
Forum Support Team
rowdy85
#33 Posted : 06 September 2013 04:15:33
Thanks Andreas, That's very helpfull. Did many people on the German RB7 forum have trouble with the front wheels being too loose? I noticed that Goose has use a 7mm wheel nut for 1/10th scale cars on his car in the official build posts. Did that end up solving the problem?
Nightrider
#34 Posted : 06 September 2013 13:23:32
Gee's that seems so far away... Only being on issue 15
Andreas
#35 Posted : 06 September 2013 15:32:43
Groups: registriert
Hi rowdy 85
Yes goose solved the problem with the front wheels that way. But now we have got a new problem with the pushrods. With every Part you put in the car its getting heavier. So you loose your hight from the car bottum to the surface off the street, I only got nearly 4 mm off space from car bottum too street surface. And when i put in the Engine it goes down further. Only the engines weight is 500gr.I think the pushrods are too short and too soft, thats why the car goes in his " knees". We try to solve this problem now.
Forum Support Team
Andreas
#36 Posted : 06 September 2013 17:07:33
Groups: registriert
Forum Support Team
DarkKnight
#37 Posted : 06 September 2013 23:11:37
Rank: Amateur level 2
Hi you need to resize the photo and repost it as it's way to big.
rowdy85
#38 Posted : 07 September 2013 05:37:33
What about a thicker oil in the shocks? the oil supplied does seem very thin. you would probably want at least a 500cst shock oil, sounds like its gonna be a heavy car.
Ford62
#39 Posted : 09 September 2013 01:02:16
Im a Subscriber
Up to Issues 24 - 27 (Sept)
I have had no Issues Whatsoever (Touch Wood)
dudsy 13
#40 Posted : 09 September 2013 12:50:36
Andreas im so jealous that your so close to finishing. The engine looks awesome. Cheers for the info
6 Pages <1234>»
This page was generated in 0.145 seconds.
