Wooden plank touching ground. Options
davyp1
#1 Posted : 01 August 2013 23:07:41
Red Medal: Red Medal
Hi
I've noticed this a while back but it's only starting to annoy me now.
It's seems something hasn't went together correctly on my build.
The front end of the plank below the car is touching the ground.
I know the front end should be lower than the rear but I'm looking a approx measurement of other builds so I know when I've corrected mine.1mm or so?
Thanks in advance.
Heinzy
#2 Posted : 02 August 2013 08:47:10
I'm affraid under the regulations that is an F.I.A disqualification
D.N.Q!!!
The only thing I can think of that would affect the front height would be the suspension set up
Have you got any pics?
The Brawn Build
Wentworth Court Dolls House
The MP4/4 Build
[ulr=http://forum.deagostini.co.uk/default.aspx?g=posts&t=36693]The 97T Build[/url]
davyp1
#3 Posted : 02 August 2013 23:55:10
Suppose its nothing a file will sort.Just wondering if anyone else had this problem and how they fixed it.
#4 Posted : 03 August 2013 11:13:50
Dave
Mines not far from what your's is and i'm ok with it. You could make a few adjustments to the front suspension arms to raise the nose of the car but be carefull not to cause damage.
davyp1
#5 Posted : 03 August 2013 16:47:53
Yes.
Think ill live with it.While I was inspecting the suspension I noticed that I had the wrong tyre on my front hub.Crying So I've set about changing them around.Removing my Ls and Rs and also correcting the stripe which i knew was wrong into the right grove by flipping to opposite side.
Still touches the ground though.If its not far from yours Spencer that'll do me.BigGrin
This page was generated in 0.113 seconds.
