Question for Mr T on gold paint Options
#1 Posted : 30 July 2013 20:51:29
Hope all is well with you.
See you have started to gold paint some of the parts and was wondering please if you would mind sharing your preferred choice of gold paint.
Kind regards
#2 Posted : 30 July 2013 21:02:18
Good thanks BigGrin
I used Tamiya TS-21 gold and XF-1 matt black for the inner window lining and face panels
#3 Posted : 31 July 2013 10:03:45
Mr T
Many thanks for the information - very much appreciated.
Always found the ThecTamiya matt black exactly that on my plastic kits.
Been finding the admiralty paints dull black is still rather "shiny"
Kind regards
#4 Posted : 31 July 2013 10:49:59
Some modellers use talc to dull down the admiralty black
benny b
#5 Posted : 31 July 2013 19:54:37
hi I was once told to get realy good gold colour is to under coat in yellow can you tell me have you heard of this thanks benny.
#6 Posted : 31 July 2013 20:09:17
BigGrin Hi Benny
For Gold, what I generaly do is undercoat the metal with your usual grey undercoat then a coat of bright red and after coat with Gold paint. Hope this helps
Captain David
#7 Posted : 31 July 2013 20:28:51
And then some gold leaf on top!
#8 Posted : 31 July 2013 21:34:08
You can dull down the black paint after with a coat of Matt varnish and this will also help hide any brush marks.
As for gold it depends on how bright you want it. I do first coat white if I want a subtle gold, I have also used yellow but for a vibrant gold I have in the past used chrome, silver or aluminium.
Best thing is to try some combinations and see what finish you like best.
J
#9 Posted : 01 August 2013 20:11:43
Thanks everyone for all the input to this question -much appreciated.
Kind regards
RobT
#10 Posted : 19 August 2013 14:12:10
Isn't the TS-21 spray paint?
I would have thought that would be pretty tricky to use on such intricate parts.
Is there an equivalent in pot form?
#11 Posted : 19 August 2013 14:26:24
Yes it is and kay to use., they do a pot gold leaf (X12) but its not as good a finish.
RobT
#12 Posted : 19 August 2013 14:43:25
Sorry, I'm a total noob on this as you are well aware.
With the smaller parts (window castings), is it just a case of spraying the whole thing with primer, then gold and then handpainting the black infills after?
#13 Posted : 19 August 2013 15:17:01
Correct, or you can brush paint if you feel more comfortable with this route.
benny b
#14 Posted : 19 August 2013 16:57:50
the best matt black I have found is tamiyas xf 69 they call it nato black but it is a flat colour
