KobusBeukes wrote:Received the next four issues, i.e. 12, 13, 14 and 15, today! Will post some pictures over the weekend! Enjoy your builds! Regards Will look forward to seeing them Kobus.... Regards Alan
Joined: 23/04/2013 Posts: 287 Points: 859 Location: Hartbeespoort, NW, South Africa
Hi Alan Thanks for the engouragement! Regards Kobus
Current Build HMS Sovereign of the Seas - First Build
Hi Kobus, your build is looking good  the guys are giving you great advice and keeping you on the right track  Good stuff kind regards Mike MWG BUILD DIARIES: HMS VICTORY, SOVEREIGN OF THE SEAS, SAN FRANCISCO II, HMS HOOD, HMS ENDEAVOUR LONGBOAT, HMS VICTORY X-SECTION, 007 DB5, NISSAN GTR, CUTTY SARK, RB7, AKAGI, BARK HMS ENDEAVOUR, HUMMER H1, MITSUBISHI ZERO.
Hi Mike I appreciate all the advice I get from the forum!  To follow the other builds is an eye opener and the modifications are stunning! Regards Kobus
I've done some work this past weekend. The dummy gun supports were cut and glued as well as the supports beams for the second deck! Decided to follow others and used 5 mm dowel stick to support the support beams. The support beams are much stronger with the dowel sticks in place! I'm considering to follow Alan (Gandale) with the prow. Alan cladded the prow with walnut and it looks marvelous! Althought mine is already glued I want to steam it loose and then cut the prow out of 1/8" (3.15 mm) solid wallnut. I know it is thinner than the 4 mm plywood but don't think it will make such a difference. Enjoy the building   Kobus
Nice clean accurate work Kobus  Now you are up and running Kind Regards Nigel
NMBROOK wrote:Nice clean accurate work Kobus  Now you are up and running Kind Regards Nigel Hi Nigel Thanks for the encouragement and looking in. Regards Kobus
Beautiful work Kobus and very well done indeed...  .. Very soon you will be planking the lady and I look forward to seeing it.... Regards Alan
Gandale wrote:Beautiful work Kobus and very well done indeed...  .. Very soon you will be planking the lady and I look forward to seeing it.... Regards Alan Hi Alan Thanks for looking in and the word of engouragement!  Much appreciated! Regards Kobus
Good work there Kobus, nice clean build, keep it up. Rgds, Hans "It's okay to make mistakes. mistakes are our teachers - they help us to to learn, even if it is painfully" Current Build: Endeavour Cross section,D51 Completed: HMS Victory Under the bench: Endeavour x 2,Sovereign of the Seas, Akagi and The Black Pearl!HMS Victory Cross Section
Joined: 02/09/2012 Posts: 515 Points: 1,515 Location: Burnley
Hi Kobus, Looking forward to seeing your progress. Regards Claret Also working on: SOTS. Moebius 1/32 Flying Sub with PE & lights.
Waiting in the wings: Polarlights Spindrift from Land of the Giants.
finished: 007 Iconic DB5.
Hi Kobus, Your progress is looking good WTG. Regards delboy271155 (Derek) COME BACK GUY FAWKES "YOUR COUNTRY NEEDS YOU"
Hi Hans, Claret and Derek Thanks for looking in and the encouragement. It is apreciated! Regards Kobus
Just a small update. Installed the second deck and sprayed the outer surfaces of the stringers and decks black.  Regards Kobus
Nice work Kobus  you are progressing well and will soon be planking Kind Regards Nigel
NMBROOK wrote:Nice work Kobus  you are progressing well and will soon be planking Kind Regards Nigel Hi Nigel Thanks for the nice feedback. Much appreciated! Regards Kobus
Another update for the day. Painted the launch with a wood primer. Tested the Humbrol RC417, ivory white, but it seems green? The stick on the right is painted white.  Regards Kobus
Hi Kobus, nicely done there and the launch is also looking good... I too used the same white and yes it looks as if it has a green tinge to it, once its on I rather liked it.....  .. Keep em coming... Regards Alan
Gandale wrote:Hi Kobus, nicely done there and the launch is also looking good... I too used the same white and yes it looks as if it has a green tinge to it, once its on I rather liked it.....  .. Keep em coming... Regards Alan Hi Alan Thanks for the feedback, was quite suprise when I opened the tin and saw the color  ! Hopefully it will turn out good. Regards Kobus
Hi Kobus another colour to try is Barley White which has a brown off white tinge that sometimes looks better than the green tinge regards Andy Current builds:-C57,Zero, Lamborghini Countach, Caldercraft HMS Agamemnon,Robi,R2-D2, MFH Cobra .
