Joined: 15/04/2010 Posts: 1,266 Points: 3,841 Location: The Quantock Hills,Somerset
claret wrote:Hi Nigel & Alan, Thanks for your comments and looking in. The bearded growth is only a touch of cocktail stickitas!  Nothing a little snipping and sanding can not cure Regards Claret Is there no medication for this as you seem to get repeat doses of it & you have spread it about a bit in a very short time span!!! Rob Nolli Illigitimi Carborundum!!!Current Builds: HMS Victory, SV Thermopylae
Looking real cool Claret, well done, she's taking shape now. As Rob says there seems to be an epidemic doing its rounds. Darn fine idea anyhow! Rgds, Hans "It's okay to make mistakes. mistakes are our teachers - they help us to to learn, even if it is painfully" Current Build: Endeavour Cross section,D51 Completed: HMS Victory Under the bench: Endeavour x 2,Sovereign of the Seas, Akagi and The Black Pearl!HMS Victory Cross Section
Nice work Claret, the lined grating holes look great
Joined: 02/09/2012 Posts: 515 Points: 1,515 Location: Burnley
Thank you very much Mr. T Regards Claret Also working on: SOTS. Moebius 1/32 Flying Sub with PE & lights.
Waiting in the wings: Polarlights Spindrift from Land of the Giants.
finished: 007 Iconic DB5.
Have to agree with abov comments the new grating and lining does make it visualy stunning and contrasts well with the oak stain - top job “Whenever you find yourself on the side of the majority, it is time to pause and reflect.” -Mark Twain
Hi Rob & Hans, Thanks for looking in and thanks for your comments. I think she is cured now, but certainly has been wide spread epidemic Regards Claret Also working on: SOTS. Moebius 1/32 Flying Sub with PE & lights.
Hi Jase, Thanks for your comments. I am certainly enjoying this part of the build after all the treenailing. Regards Claret Also working on: SOTS. Moebius 1/32 Flying Sub with PE & lights.
Hi, I finished the secondary planking, treenailing and finished it off with a sanding down with P240 sandpaper. The model was now ready for painting.   Regards Claret Also working on: SOTS. Moebius 1/32 Flying Sub with PE & lights.
Joined: 17/11/2012 Posts: 863 Points: 2,608 Location: Gohfeld (Germany)
Hi Claret! That´s looking great, well done! Regards, Bernd
Hi, Just finished the black painting on the top part of the hull. I have tried airbrushing for the first time, and quite pleased with the result. I measured and masked the area to be painted. I used Tamiya masking tape. By far more superior than 'normal' DIY masking tape. The paint Wilko's matt Black and is very matt and has given a nice matt finish. result is below.  Thanks for looking in. Claret Also working on: SOTS. Moebius 1/32 Flying Sub with PE & lights.
Thanks Bernd for looking in and the kind comments. Regards Claret Also working on: SOTS. Moebius 1/32 Flying Sub with PE & lights.
She looks fab Claret  Lovely work Kind Regards Nigel
Now that just goes to show how much all your efforts were worth while Claret....  .. Very well done indeed, she is looking great.... Regards Alan
Hi Nigel & Alan, Thanks for looking in and your kind comments, appreciated as always. Regards Claret Also working on: SOTS. Moebius 1/32 Flying Sub with PE & lights.
Joined: 24/09/2012 Posts: 491 Points: 1,452 Location: London
a lovely result claret, great work here Processing - Progressing
Previous builds: HMS Victory Current build: HMS Sovereign of the seas
Thanks Admiral. Appreciated. Claret Also working on: SOTS. Moebius 1/32 Flying Sub with PE & lights.
Hi All, Update on my progress over the weekend. Glued the bow sprite and keel into place. Masked off and painted the red band using Admiralty Red Ochre with an airbrush. I also painted the canon port surrounds at the same time.    Now contemplating whether to invest in a compressor for the airbrush rather than using tins. Not sure what to get though! Thanks for looking in. Regards Claret Also working on: SOTS. Moebius 1/32 Flying Sub with PE & lights.
Hi Dominic, Thanks for the comments and looking in. The admiralty paint airbrushed okay. I used water to thin it and gave it a few coats because of the contrast with the basswood and sapele. Regards Claret Also working on: SOTS. Moebius 1/32 Flying Sub with PE & lights.
Very nice paint job Claret, well done to you...  .. Think you would find investing in a compressor would save you money in the long run with not having to shelve out on cans of compressed air.... Regards Alan
Lovely paintwork Claret  The colour is spot on and will look brill with the wales. Kind Regards Nigel
Guest (5)
