Good job, Derek, well done. Rgds, Hans "It's okay to make mistakes. mistakes are our teachers - they help us to to learn, even if it is painfully" Current Build: Endeavour Cross section,D51 Completed: HMS Victory Under the bench: Endeavour x 2,Sovereign of the Seas, Akagi and The Black Pearl!HMS Victory Cross Section
 Nice work Derek keep the pics coming  Rgd Martyn Building ? Completed. Soliei Royal . Sovereign of the Seas . Virginia . Scotland . San Felipe . Corel vasa , Santisima Trinadad X section , Vasa Next Build ? When sailors have good wine, They think themselves in heaven for the time. John Baltharpe
Gandale wrote:Looking good Derek and you did the right thing by adding the extra plank...  .. As long as you are above the ribs then you will be fine... Well done m8.... Regards Alan Hi Alan, Thanks for looking in, it`s onto side two tomorrow as I`ve got a day off Regards delboy271155 (Derek) COME BACK GUY FAWKES "YOUR COUNTRY NEEDS YOU"
NMBROOK wrote:WTG Del  .As Alan said will sand down well,but don't forget about the hull profile post. Kind Regards Nigel Hi Nigel, Thanks for looking in, the sanding could be fun but got to plank top of second side tomorrow. Could you expand on the "hull profile post" not sure what you are getting at, just got home from a 13 hour day at work and not fully tuned in yet. Regards delboy271155 (Derek) COME BACK GUY FAWKES "YOUR COUNTRY NEEDS YOU"
Hans wrote:Good job, Derek, well done. Hi Hans, Thanks for looking in and kind comments. Regards delboy271155 (Derek) COME BACK GUY FAWKES "YOUR COUNTRY NEEDS YOU"
Martyn Ingram wrote: Nice work Derek keep the pics coming  Rgd Martyn Hi Martyn, Thanks for looking in and kind comments, will update when side two is up to the top. Regards delboy271155 (Derek) COME BACK GUY FAWKES "YOUR COUNTRY NEEDS YOU"
delboy271155 wrote:NMBROOK wrote:WTG Del  .As Alan said will sand down well,but don't forget about the hull profile post. Kind Regards Nigel Hi Nigel, Thanks for looking in, the sanding could be fun but got to plank top of second side tomorrow. Could you expand on the "hull profile post" not sure what you are getting at, just got home from a 13 hour day at work and not fully tuned in yet. Regards delboy271155 (Derek) Hi Del,it was the post that led you to find the distorted rib at the stern,it shows you the common depression to look out for as ideally it wants filling before second planking. Kind Regards Nigel
NMBROOK wrote:delboy271155 wrote:NMBROOK wrote:WTG Del  .As Alan said will sand down well,but don't forget about the hull profile post. Kind Regards Nigel Hi Nigel, Thanks for looking in, the sanding could be fun but got to plank top of second side tomorrow. Could you expand on the "hull profile post" not sure what you are getting at, just got home from a 13 hour day at work and not fully tuned in yet. Regards delboy271155 (Derek) Hi Del,it was the post that led you to find the distorted rib at the stern,it shows you the common depression to look out for as ideally it wants filling before second planking. Kind Regards Nigel Cheers Nigel,  That jogged the old grey matter into gear and yes I`ve got the suitable filler to hand already. Many thanks for the memory jog Regards delboy271155 (Derek) COME BACK GUY FAWKES "YOUR COUNTRY NEEDS YOU"
Hi All, Well, I`ve found time for an update. Delay due to pressures of work and wanting to get on with second planking, unfortunately the pressure of work took front of stage (can`t wait to retire  ). The pics will explain what`s been going on, suffice to say it ain`t all been plain sailing as you will already probably know  . Pics will show: Gun port marking Gun port cutting Second planking at various stages (one side only so far) Thanks to Gandale (Alan), as I have started lower hull 2nd planking and his close up pics have been invaluable. Well that`s it for now, will update again asap Regards delboy271155 (Derek) delboy271155 attached the following image(s): COME BACK GUY FAWKES "YOUR COUNTRY NEEDS YOU"
 Bril work delboy keep it up  Rgd Martyn Building ? Completed. Soliei Royal . Sovereign of the Seas . Virginia . Scotland . San Felipe . Corel vasa , Santisima Trinadad X section , Vasa Next Build ? When sailors have good wine, They think themselves in heaven for the time. John Baltharpe
Great work Del  .No updates for a bit,then WHAM Kind Regards Nigel
Lovely work on the planking Derek, very very well done to you.....  .. It may be a slow process but the results you are getting are very much worth your efforts so keep it going.... Regards Alan
Joined: 24/09/2012 Posts: 491 Points: 1,452 Location: London
Lovely work on the planking and gun ports del, gun ports are a pain but you seemed to of done well with them Processing - Progressing
Previous builds: HMS Victory Current build: HMS Sovereign of the seas
Good job Derek, looks like your coming on in leaps and bounds. Rgds, Hans "It's okay to make mistakes. mistakes are our teachers - they help us to to learn, even if it is painfully" Current Build: Endeavour Cross section,D51 Completed: HMS Victory Under the bench: Endeavour x 2,Sovereign of the Seas, Akagi and The Black Pearl!HMS Victory Cross Section
Joined: 02/09/2012 Posts: 515 Points: 1,515 Location: Burnley
Hi Derek, That is looking very nice indeed. Keep up the great work. Regards Claret Also working on: SOTS. Moebius 1/32 Flying Sub with PE & lights.
Waiting in the wings: Polarlights Spindrift from Land of the Giants.
finished: 007 Iconic DB5.
Martyn Ingram wrote: Bril work delboy keep it up  Rgd Martyn Hi martyn, Thanks for looking in and the kind comments. Regards delboy271155 (Derek) COME BACK GUY FAWKES "YOUR COUNTRY NEEDS YOU"
NMBROOK wrote:Great work Del  .No updates for a bit,then WHAM Kind Regards Nigel Hi Nigel, Well it`s like this, had loads of work on and fitted in as much time on the build as possible and overlooked the diary. Then SWMBO stuck her two penny worth in "you spend every minute blah blah blah **** blah blah", so hence the update just before i ducked the missiles So, thanks for looking in and the kind comments. Regards delboy271155 (Derek) COME BACK GUY FAWKES "YOUR COUNTRY NEEDS YOU"
Gandale wrote:Lovely work on the planking Derek, very very well done to you.....  .. It may be a slow process but the results you are getting are very much worth your efforts so keep it going.... Regards Alan Hi Alan, Thanks for looking in and the kind comments. Just glad to see the back of the bamboo planking (even though there are a few places for it yet). I am now really enjoying the progress, but still taking the second look before I take the plunge on each stage. Regards delboy271155 (Derek) COME BACK GUY FAWKES "YOUR COUNTRY NEEDS YOU"
Admiral Anti Spiral wrote:Lovely work on the planking and gun ports del, gun ports are a pain but you seemed to of done well with them Hi Admiral, Thanks for looking in and the kind comments. You are spot on with the the ports being a pain (especially in bamboo). My method was to use a dremel with a small round reamer bit. With that I took out the bulk of the scrap, then took a new blade (8 in total) to do the trimming up to the markings. I`m now really enjoying the second planking layer and looking forward to getting into some of the finer details. Regards delboy271155 (Derek) COME BACK GUY FAWKES "YOUR COUNTRY NEEDS YOU"
Hans wrote:Good job Derek, looks like your coming on in leaps and bounds. Hi Hans, Thanks for looking in and the kind comments. Regards delboy271155 (Derek) COME BACK GUY FAWKES "YOUR COUNTRY NEEDS YOU"
