Joined: 02/09/2012 Posts: 515 Points: 1,515 Location: Burnley
Hi, Just a couple of photos for all the cocktail stick fans Almost finished top side treenailing. Regards Claret   Also working on: SOTS. Moebius 1/32 Flying Sub with PE & lights.
Waiting in the wings: Polarlights Spindrift from Land of the Giants.
finished: 007 Iconic DB5.
Joined: 24/09/2012 Posts: 491 Points: 1,452 Location: London
lovely work claret  the treenailing will be a great added detail Processing - Progressing
Previous builds: HMS Victory Current build: HMS Sovereign of the seas
I miss those sticks, they should be part of my collection......  .. Lovely work Claret, very well done..... Regards Alan
Joined: 06/12/2012 Posts: 152 Points: 439 Location: Barrow-in-Furness Cumbria
Hi Alan, Many thanks for the comments, but they are all mine!  I have found a cocktail stick mine here in east lancs. Regards Claret Also working on: SOTS. Moebius 1/32 Flying Sub with PE & lights.
Thanks admiral. I am pleased how they have turned out. Regards Claret Also working on: SOTS. Moebius 1/32 Flying Sub with PE & lights.
Hi Stu, Sorry for not replying earlier, have been in mid Wales for my sons graduation. The glue is the aliphatic type supplied by CMB. Alan (Gandale) has a photo in one of his posts. I drill a 0.5mm hole and cut the cocktail stick in half before dipping the end in glue and inserting into the drilled hole. Generally the stick is sharply tapered, but if not I have gently whittled the end to a point with a sharp scalpel. Hope this helps. Regards Claret Also working on: SOTS. Moebius 1/32 Flying Sub with PE & lights.
claret wrote:Hi Stu,
Hope this helps.
Regards Claret thanks claret. and my congratulations to your son. Cheers Stu
Thanks Stu. Also working on: SOTS. Moebius 1/32 Flying Sub with PE & lights.
Hi, Just having a break from planking and tree nailing. I glued the assembly together, let the glue cure, but as I am using 1mm grating, i had to put an additional cross member in to ensure all the holes were less than 33x33mm to fit the new grating. i scored and pencilled the cross members to look like plank assemblies but struggled for treenails. I remebered I had some hornby track pins, they are very thin and worked a treat. The photo shows the pins glued in place before cutting down.  More to follow soon. thanks for looking in. Claret Also working on: SOTS. Moebius 1/32 Flying Sub with PE & lights.
Really like what you have done there Claret, very well done..... Regards Alan
Thanks Alan, Always appreciate your comments and looking. Regards Claret Also working on: SOTS. Moebius 1/32 Flying Sub with PE & lights.
Nice out of the box thinking there Claret Kind Regards Nigel
Thanks Nigel, It is not very often I am allowed out of the box, especially unsupervised! Thanks for looking in. Regards Claret Also working on: SOTS. Moebius 1/32 Flying Sub with PE & lights.
nice work claret  i was thinking of getting some of those pins a while back Processing - Progressing
Hi Admiral, Thanks. They are only blackened on the surface, so bright metal once cut off, but still looks okay. Regards Claret Also working on: SOTS. Moebius 1/32 Flying Sub with PE & lights.
Hi, Finished the first stage of the secondary planking, so glued the gallery supports ready to take the transom.  Whilst waiting for the glue to cure with the transom clamped in place, I did some more work on the bow beak. I stained the wood with dark oak, giving it three coats. I also lined all the holes with basswood before starting to fit the 1mm grating I purchased from CMB's. My progress so far is shown in the pics below.   Thanks for looking in. Regards Claret Also working on: SOTS. Moebius 1/32 Flying Sub with PE & lights.
Lovely work Claret  I like the basswood lined holes,the cut gratings will look so much better for it  Oh and are you aware of a strange beardlike growth on the stern? Kind Regards Nigel
Lovely work there Claret and I have to agree with Nigel, very nice idea lining the holes for the gratings, will give a much better finish....  .. Regards Alan
Hi Nigel & Alan, Thanks for your comments and looking in. The bearded growth is only a touch of cocktail stickitas!  Nothing a little snipping and sanding can not cure Regards Claret Also working on: SOTS. Moebius 1/32 Flying Sub with PE & lights.
Guest (10)
