Entry ports Options
#1 Posted : 12 July 2013 22:21:16
Hi All, BigGrin BigGrin
Do we, anywhere in the run of things know if the entry ports will be in the open or closed position?
Reason for asking is, if, they will be open then the dummy gun supports will be visible and I would prefer to remove that section and show internal decking albeit a small amount.
I am decking that section just in case any lower deck is visible through the hatches, so would rather deck all the area in one go while I`m at it.
Admiral Anti Spiral
#2 Posted : 12 July 2013 22:33:58
it'll probably be closed but then again what would be the reason for the big hole if it was to be closed, a good question, but its probably better to close it because other than a planked deck theres no much to see
Processing - Progressing
Previous builds: HMS Victory
#3 Posted : 12 July 2013 22:35:36
I am guessing they may be open, because the dummy gun support beams have been deliberately extended past them.
You might be able to identify for sure via the Italian site.
NMBROOK
#4 Posted : 12 July 2013 22:44:42
Hi Del
The Italian site hasn't got that far yet.I would have edged my bets that the entrance port is closed and is a complete casting,surround with door.Hence the hole to clear the back of the door as it is recessed.There is nothing in the Italian build to suggest any different as no internal detail has been fitted.
Kind Regards Nigel
#5 Posted : 12 July 2013 23:08:32
Thanks Guys,BigGrin BigGrin
Have checked the Italian site and can confirm as stated "they ain`t got that far" and agree that it will most likely be closed, because on further thought I`m thinking, that if the gun ports are open with the cannon pointing out to sea, then it`s unlikely they will have an open door policy. LOL LOL LOL LOL LOL LOL LOL LOL .
Thanks for looking in and your thoughts,Cool
#6 Posted : 12 July 2013 23:14:25
BigGrin Hi Del
Have a look here, it might be of help
http://www.model-space.c...ign-of-the-seas/details
#7 Posted : 12 July 2013 23:19:16
arpurchase wrote:
BigGrin Hi Del
WTG Andy,BigGrin BigGrin
Well spotted, just goes to show you can look at something and still not see (won`t tell you how many times I must have missed that one Crying )
Thanks,BigGrin
This page was generated in 0.102 seconds.
