Joined: 23/04/2013 Posts: 287 Points: 859 Location: Hartbeespoort, NW, South Africa
Tomick wrote:Hi Mike,
The interior and exterior of the ship's boat is painted in issue 15. The exterior is stated as ivory white, and the interior burgundy.
I plan to use Humbrol RC418 as the burgundy and RC417 as the ivory. This quote is on page 11 of the SOTS General build discussion. Hope this helps Regards Kobus
Current Build HMS Sovereign of the Seas - First Build
Joined: 07/05/2013 Posts: 10 Points: 30 Location: Cape Town
Hi Guys Did CNA stop stocking the magazine? They have no idea its not on da shelves. Plus they said it may have switched over to a fortnight, that means this project will take over 5 years. Regards CJ Current Build - HMS SOTS
 Rank: Beginner Level 3  Groups: Registered
Joined: 05/04/2013 Posts: 26 Points: 78 Location: South Africa
Hello CJ
I have the same problem with them. I spoke to the woman managing the partworks and she said she will find out and give me a call on Thursday. If I find out something useful I will pass it on. Thought it was just me because I live in Namibia. Around here thing go slower.
With regards to the fortnight issue, I think they are just confused. CNA told me from the start that it would be published every two weeks but it came out weekly since the start.
Regards Hendrik
Thanks for the tip guys. I actually purchased paints from CNA, i think its called Dala paints, Ivory and Maroon and it turned out pretty good I must say. Regarding the CNA issue I hope its positive, alternatively We may have to switch over to postal coz that too does not sound so promising but anyway Regards Mogamad (CJ) Current Build - HMS SOTS
Good Day Guys For all those that purchase through CNA, I got a response today and was advised that delivery was late for issue 16 and it will be in store on Sunday, however I do not know if it will also include issue 17 aswell. But we will have to see. And the build goes on Current Build - HMS SOTS
 Rank: Amateur level 2     Groups: Registered
Joined: 09/07/2013 Posts: 41 Points: 123 Location: Alberton, South Africa
Hans wrote:Hi fellow builders. Any SA SOTS builders taking up the challenge?? Thought I would take up your challenge, I subscribed yesterday. I will have to finish the San Fransisco first (as well as the 1/32 Lancaster !!) But I'm really looking forward to the challenge...Hans I'd love to get together soon to "spy" on your builds Regards Steve Present Build: San Fransisco II, 1/32 Lancaster Bomber
Subscribed to: Sovereign of the Seas
Completed: La Toulonnaise, Harvey
Welcome to the house of fun, Steve. Your welcome anytime, just give me a call. I will be here this week and the away for a week. Rgds, Hans "It's okay to make mistakes. mistakes are our teachers - they help us to to learn, even if it is painfully" Current Build: Endeavour Cross section,D51 Completed: HMS Victory Under the bench: Endeavour x 2,Sovereign of the Seas, Akagi and The Black Pearl!HMS Victory Cross Section
Joined: 25/04/2013 Posts: 71 Points: 216 Location: Benoni, South Africa
Issue 16 was available at CNA yesterday but it seems that issue 17 will be out next week as the CNA's do not have it Current Build: HMS SOTS HMS Victory HMS Surprise
Hi Guys Issue 17 and 18. Plank bending. I need help. Would really appreciate it if a break down can be give on how to bend planks. I don't have the tool just bits and piece on other users. Im a bit stuck on how to bend. Regards Mogamad Current Build - HMS SOTS
Hi Mogamad. It is not all that difficult. Soak your plank or planks in hot water for 10 - 20 minutes, if you don't have a plank bender to score slots in the plank in the required position use a mini saw. Fold round a coffee tin or object about the same bend, hold in place with am elastic band till dry, offer up to your build and fit. Another method is the same as above and fit to your build, semi pin in place and allow to dry. When dry, glue and fit. I personally soak and bend with a soldering iron while wet to achieve the right shape. If it is a slight bend, steam can help, from a kettle or steam machine. Just be careful steam can burn as well as the soldering iron. All the above ideas are not mine, but what has been suggested on the forum. Hope it helps. Rgds, Hans "It's okay to make mistakes. mistakes are our teachers - they help us to to learn, even if it is painfully" Current Build: Endeavour Cross section,D51 Completed: HMS Victory Under the bench: Endeavour x 2,Sovereign of the Seas, Akagi and The Black Pearl!HMS Victory Cross Section
Hi Mogamad, there are many ways to achieve the desired results and a good tip would be to read a few of the diaries relating to other builds.... My preferred method is the use of steam from the kettle, holding the strips using long nosed pliers. If it is hardwood then I have been known to put the planks into a pressure cooker but not allowing the planks to touch the water at the bottom, this has also worked for me....  .. Am sure with a little trial and error, a little research and you will find your own preferred method....  .. Good luck and keep at it.... Regards Alan
Thanks Guys Will be trialing and testing as much as I can lol. Regards Mogamad Current Build - HMS SOTS
Joined: 18/08/2013 Posts: 12 Points: 36 Location: Durban, KZN, south africa
Hey Hans,
Yip, durbanite here as well.
As a complete newbie to models, i only know of hobbietech in Westville, was gobsmacked and in awe of all the awesome stuff they had, but if there is any other stores i might be missing out on?
Looking forward to the build ahead.
Cheers Duane
Lovely stuff Duane, will have a look at your build. Rgds, Hans "It's okay to make mistakes. mistakes are our teachers - they help us to to learn, even if it is painfully" Current Build: Endeavour Cross section,D51 Completed: HMS Victory Under the bench: Endeavour x 2,Sovereign of the Seas, Akagi and The Black Pearl!HMS Victory Cross Section
Joined: 05/09/2010 Posts: 123 Points: 358 Location: Valhalla, Pretoria
Hi to all Compliments of the season to all SotS builders. I have returned from Mali and am busy completing the Victory, busy with the ratlines. To date I have received up to Issue 36 as well as the free gift (small power tool in case). I receive my order from Jacklin and to date have had no problems even with the postal system. I am busy reading what the rest of the builders are up to and as soon as I have finished the Victory, a build log will be started. Cheers Andre Current Build: HMS Victory
Built: HMS Bounty
Next Build: Sovereign of the Seas Started collecting. Redrawing of plans for Santisima Trinidad for a scratchbuild. Santisima Trinidad - waiting for launch.
Welcome to the other house of fun, Andre. Enjoy your reading, there are volumes and volumes of info. Rgds, Hans "It's okay to make mistakes. mistakes are our teachers - they help us to to learn, even if it is painfully" Current Build: Endeavour Cross section,D51 Completed: HMS Victory Under the bench: Endeavour x 2,Sovereign of the Seas, Akagi and The Black Pearl!HMS Victory Cross Section
