gun port marking/cutting Options
#1 Posted : 03 July 2013 17:00:13
Hi All,BigGrin BigGrin
Just marked out one side with top edge,gun ports and entry port and have a question Confused .
The guide lines along the hull obviously rise toward the stern, so my question is, do you cut the bottom edge of a port exactly to the line or do you make it horizontal to the base?
If cut to the line then the sides of the ports will be very slightly off the vertical.
Advise please,BigGrin BigGrin
Don`t want to start cutting till I`m sure it`s right Blink
NMBROOK
#2 Posted : 03 July 2013 17:12:01
Hi Del
The bases of the gunport should be horizontal.When you say guideline,I assume you mean the line thats 5mmish above the deckline you had to draw along the hull.
Kind Regards Nigel
#3 Posted : 03 July 2013 17:17:50
Hi Del
Kind Regards Nigel
Cheers Nigel,BigGrin BigGrin
Thanks very much for looking in and the advise. You assume right about the line and as I thought, but needed confirmation was as you say, that the ports should be in a vertical plane.
Many thanks again,Cool Cool
RobT
#4 Posted : 19 August 2013 19:31:05
This was causing me some issues as well. Maybe it's an optical illusion, but the upward curve of the stern makes the ports look more curved. So I knocked up a crude diagram.
Is this how the ports must be cut?
budgie
#5 Posted : 19 August 2013 19:49:37
BigGrin Hi Rob
IMHO if the deck which the canons sit on slopes up the gunports will need to as well, as the canons will protrude thru the gunports at different levels or maybe not at all
RobT
#6 Posted : 19 August 2013 21:23:53
I kind of see what you mean. but I look at some models, and it seems to my eye that the rear gunports are going like this:
As I say, maybe the general slope of the sterm causes an optical illusion, but I would just like confirming which of these is the correct way.
NMBROOK
#7 Posted : 19 August 2013 21:26:29
You are both correct as the deck curves upwards the gunports follow it.Your sketch Rob is spot on as to what you are trying to achieve.
Kind Regards Nigel
NMBROOK
#8 Posted : 19 August 2013 21:28:57
The second sketch is wrong Rob,the sides must remain plumb and the top and bottom horizontal.The only ship I know of where the ports tilt with the deck,is the swedish Vasa
Kind Regards Nigel
This page was generated in 0.133 seconds.
