Decal help for McLaren MP4/7 Options
Kratos8051
#1 Posted : 01 July 2013 15:10:59
Rank: Amateur Level 1
Hi guys,
I need your help. I bought the McLaren MP4/7 (McLaren) for a friend. However, something is a bit off with the decals. The instructions state that the decals should be left in water for 10 seconds, before removing the backing and sticking it. But after 10 seconds, the backing doesn't want to come loose. So he has to leave it for a while longer. Eventually it becomes possible to remove the decals, but it is practically impossible to stick it. The paper is so brittle, that even a slight blow or touch perishes the decal completely. Is he doing something wrong, or did I buy him a rubbish model?
#2 Posted : 01 July 2013 17:59:58
Hi Kratos
sounds like you got a faulty batch of decals, get in touch with CS to get a replacement set
#3 Posted : 01 July 2013 19:11:41
It does sound like the decals have been sitting for some time and tend to break up... when putting decals into water make sure it is warm water as this then tends to make the backing paper soak the water more quickly.
I'm guessing this MP4/7 is and older kit form years gone by?
Spencer
Kratos8051
#4 Posted : 02 July 2013 11:08:23
Thanks for the replies, guys. Sorry,I see the link I posted is broken. Let me try again, this is the model in question: Link
Thanks for the warm water tip, Warthog. Will tell him to try it.
Regarding the replacement decals, how and where can I order some (preferably someone who ships internationally)? I bought the kit from a local hobby shop, and since it is an old kit, I doubt I will be able to get a replacement there.
#5 Posted : 02 July 2013 17:44:25
BigGrin Hi you could try contacting Tamiya direct by e-mail, there usally pretty decent with replacements if available Cool
#6 Posted : 02 July 2013 20:04:37
There are a couple off suppliers and the main one is Hiroboy.com but they are out of stock.. I googled the decals but mainly coming up with 1/18 scale and not 1/20... EBay is the likely place you will find some
Spence
Kratos8051
#7 Posted : 03 July 2013 19:14:03
Thanks for the replies guys! I will see what I can do.
This page was generated in 0.230 seconds.
