6 Pages 123>»
1/84 Cannon Crest Stamp. Options
Capt Stedders
#1 Posted : 09 June 2010 19:41:32
Before I begin this topic, I should make it absolutely clear that the following offer is unconnected with DeAgostini (or any of its agents and operatives) and that both the design of the tool and rights connected with it belong solely to me..
Thanks.
Ahoy Shipmates!
After receiving both a prompt and a commission to make a cannon crest stamp like the one I made for my own build, I decided to sit down and design a tool that would make it (relatively) simple to apply the cast crest, applique detail on the cannon and carronade barrels.
After a not altogether-satisfactory start with some cheap pine dowling, (which absolutely refused to stop fluffing up, even after 3 coats of sanding sealant, 2 coats of filler primer, a coat of black paint and some varnish) I settled on an ergonomically - shaped walnut handle, an aluminium ferrule and brass alignment stud. The detailing end is made from cured Greenstuff/Kneadatite which, given that it is used to create master sculpts for centrifugal casting machines means that it is pretty tough stuff.
The 1/84 Cannon Crest Stamp.
Note: The quality of finish on the completed tool handle is of a much higher standard than that shown in the above pics.
The tool will be supplied either 'as is' for £5 or, for a couple of golden nuggets (£2) more, enough GS to do all 24 supplied cannon. (whilst the amount supplied will be more than sufficient for both the supplied cannon/s and carronades - including an allowance for having a practice on the cannon and carronade models that you already own, it will need to be applied to small batches of cannon, say 5- 10 at a time - it's hard to mix very tiny quantities of GS at a time and this will result in waste.
How does it work?
1) Mix up, very thoroughly, a small (about 2mm diameter when mixed and rolled into a ball) amount of GS and apply it to the top centre of the portion of the cannon that you wish to embellish. – Use the pinion as the true indication of which side of the cannon barrel is ‘up’ – the thimble on your cannon may be mis-aligned .
2). Next, using a flat blade (I just so happened to have a sculpting tool handy), flatten the GS out to an even thickness (about 0.5mm) and slightly larger than the area of the stamp detailing surface. I use a sparing amount of Vaseline on the sculpting tool to help lubricate it and stop the GS sticking to it – others use spit. Just remember that, if you have used Vaseline, you’ll need to give the whole area a wash in warm soapy detergent otherwise you might have problems getting paint to stick.
3).Using the brass dot as a rough guide, a careful line up using your eye and a steady hand, press the tool down onto the GS, its not a bad idea to apply just a tiny bit of Vaseline (or spit) – if you haven’t already done so – to the surface of the GS on the cannon barrel – this will help prevent GS sticking to the detailing tool – think of it as a mould release agent.
Don’t worry if it comes out a bit askew (as it often does for me) simply re-arrange the old or re-apply some new GS to the barrel and try again . I have tried to make the lining-up process as straightforward as I can through the design, but it’s still a bit hit and miss when you get down to it.
4). Simply wait until the GS is cured (a couple of hours in a warm room should be ok for this purpose – it takes 24Hrs to fully cure, beyond any doubt) and simply cut and scrape away any surplus GS using a really sharp craft or scalpel blade. – there’s no need to cut right to the edges of the lettering or crown – just ‘close’ to the main outline. If you used vaseline, then be sure to give the cannon a quick wash with warm water and a drop of washing up liquid (I use an old paintbrush with short bristles and gently work a soapy solution in and around the affected areas).
5). Paint in a suitable shade of Black (I used a mix of Vallejo Matte Black and some Cuprinol Acrylic, Satin Finish varnish).
I make no bold claims about it being accurate to scale (in fact it's slightly oversized - a concession I made to you actually being able to make out detail on the crown and lettering as opposed to something resembling a small blob sitting over two squiggly blobs - but I will guarantee that if your tool degrades or breaks over the next couple of years (in normal useage), just send it back and I'll repair or replace it.
Each tool costs £5 (supplied without two part epoxy putty) plus P&P (a stamped addressed envelope is preferred), or £7 with sufficient material to imprint crests on 24, 1/84 scale cannon barrels (and two 1/84 carronades).
If you'd like one of these tools or have any questions, please add a comment to that effect below and I will contact you accordingly. Please note that they will be made to order and as such may take around seven days to reach you after payment is received.
Schnellboots on back burner
Tools.
andylangtree
#2 Posted : 09 June 2010 20:00:35
Yes interested for the £7 offer.
john burgess
#3 Posted : 09 June 2010 20:00:55
Jolly good "SIR" put me down for one
If you dont suceed at first go to the pub
Jamie
#4 Posted : 09 June 2010 20:08:59
What a star ThumpUp
I take one please with GS thank you very much nice doing business with ya BigGrin
I wish I were a glow worm,
A glow worm's never glum,
'Cause how can you be grumpy?
When the sun shines out ya bum!!
rogthedodge
#5 Posted : 09 June 2010 20:18:25
Rank: Amateur level 2
Yes Please Drool
jonny5j
#6 Posted : 09 June 2010 20:22:26
Yes please capt £7 one for me
cheers
john
HMS VICTORY
HMS SURPRISE
ASTON DB5
MCLAREN MP4-23
#7 Posted : 09 June 2010 20:31:26
Stedders, you never cease to amaze me!!!Love
I will take one please, with the gs.Drool
Not sure if i can do you justice, but for that price i am willing to give it a go!!!
(ps i think there will be quite a few takers! Are you sure you'r going to have time for your build???)
Graham
budgie
#8 Posted : 09 June 2010 20:33:11
BigGrin Hi Captain forgot to ask in email about SAE
do you know the price for postage
weight etc as need to put the correct amount of stamps on envelope?
envelope ~wi ll an A4 jiffy bag do?
BigGrin BigGrinthankfully u wernt kidding bout pimpin'BigGrin BigGrin
Jenny Wren
#9 Posted : 09 June 2010 20:33:37
BigGrin Love Ohhhh yes please been trying to make myself and got very frustrated!!! £7 one. Cheers Kay
Capt Stedders
#10 Posted : 09 June 2010 20:35:16
PM's sent..
The tool is actually rather small - 10cm in length - so will fit in a small, letterbox sized, envelope quite easily - and is so light that even when accompanied by GS a first class stamp should cover it.
I forgot to add that if anyone has a need for a similar tool for another build, I'll be happy to make one to your specifications (price will vary though).
*goes back to filing oar slots in launch*
*Quick tip; when filing the oar slots out, try clamping a spare bit of planking wood to the outside hull directly across the spot of hull that you are filing - this will reduce the risk of splintering and give you a tidy looking oar slot.
Tools.
Trotsky
#11 Posted : 09 June 2010 21:35:45
I am interested in the £7 deal please
David
H.M.S Victory
H.M.S Victory X Section
H.M.S Surprise under the bench
D-51
John Wreford
#12 Posted : 09 June 2010 21:49:56
And another one please.
John
Horatio's Eyepatch
#13 Posted : 09 June 2010 22:22:11
What a marvellous gesture John.
I work for the tax office..Flapper
I would like to take you up on your offer please - the £7 option.
Thank you xxx
eoinkm
#14 Posted : 09 June 2010 22:23:20
Rank: Amateur Level 1
I would like to have one please cpt for £7.
Cheers and great work.
Eoin
Wilfy the Sea Dog
#15 Posted : 09 June 2010 22:52:37
Hi,
Great idea.
Am interested in the £7.00 offer please.
Re Postage: 1st Class Large Letter stamp?
Thanks
tf5600
#16 Posted : 09 June 2010 23:07:26
Put me down for one capt ( £7 ) Ferret
Capt Stedders
#17 Posted : 10 June 2010 00:40:02
Wow! Thanks for the interest everyone - you should all have PM's by now, nestling in your forum inbox explaining details.
Important Update
Jamie Has PM'd me explaining that, owing to rather illogical (to mere mortals) postal rules the stamped addressed envelope that you send should have a 1st class, large letter stamp applied to it since the tool and packaging are slighty wider than 5mm thick...
*mutter*
Thanks for the information Jamie. ThumpUp
Don't worry if you have already posted interest and sent an SAE and payment, I'll cover the extra postage for you.
Tools.
amipal
#18 Posted : 10 June 2010 00:42:50
You are truly a gentleman sir! Please add me to your £7 list please - I was going to give this a go myself, but since there's a tool on offer... Laugh
#19 Posted : 10 June 2010 00:55:15
Mr steadders you are my hero!! I would like to purchase one of your fine stamps at the modest sum of £5.
I may well be looking for a further stamp when we get to the hull entrance that from the photos appears to lack any of the moulding detail.
Your a gent and a scholar and DeAgostini should be offering you a free subscription for your contribution to all our builds!!Cool
tom.ganc
#20 Posted : 10 June 2010 00:57:28
£5 option for me please BigGrin BigGrin BigGrin
6 Pages 123>»
This page was generated in 0.187 seconds.
