 Hi Yaturo Are you reading my mind my friend  that idea had already crossed my mind and I was planning something like that , as the saying goes' great minds think alike' regards Andy Current builds:-C57,Zero, Lamborghini Countach, Caldercraft HMS Agamemnon,Robi,R2-D2, MFH Cobra .
 Rank: Vice-Master       Groups: Registered
Joined: 21/04/2012 Posts: 747 Points: 2,233 Location: Tokyo, Japan
Hi Andy! UK is too far for me to read your mind.  I'm looking forward to seeing your idea here. Best Regards, Yutaro DeAGOSTINI 1/250 the YAMATO, 1/250 the AKAGI. Hasegawa Co. 1/350 Battle ship NGATO, 1/350 Aircraft carrier Akagi, Battle ship MIKASA. Water line series 1/700 Battle ship YAMATO, HIEI, YAMASHIRO, Aircraft carrier HIRYU,TAIHO, Heavy Cruiser Myoukou, Ashigara, Nachi, Haguro & others.
Joined: 14/03/2013 Posts: 43 Points: 129 Location: Calwell ACT AU
Hi Andy She sure is looking good, well done. I've decided to stick the decks down as well, like Yaturo, once she's in the display cabinet, she won't get touched. Phil You only live once, but if you work it right, once is enough.
Building - Bismarck, Akagi, Warspite, Gato, USS Enterprise (carrier) and D51
 Hi Yaturo and Phil Thanks for your comments and looking in regards Andy Current builds:-C57,Zero, Lamborghini Countach, Caldercraft HMS Agamemnon,Robi,R2-D2, MFH Cobra .
 Hi All This months parts have arrived [issue 23, 2 issue's left] so here's the first lot of pic's . The crane gantry has been made up as have the two search light pods and fixed in place. Another rearward platform has been added and the last large anti aircraft gun platform added with its associated support. More to follow regards Andy arpurchase attached the following image(s): Current builds:-C57,Zero, Lamborghini Countach, Caldercraft HMS Agamemnon,Robi,R2-D2, MFH Cobra .
Looking great Andy, just two more issues to go and that will be the end of another fab build...  .. What will be you priority after this one then...... Look forward to seeing the finshed build... Regards Alan
 Hi Alan Thanks for looking in and your comments after the Akagi is finished il still have the Bismark, Samurai, D51 and Zero builds to keep me busy for a while im looking at the Trinidad also as a build so lots to do regards Andy Current builds:-C57,Zero, Lamborghini Countach, Caldercraft HMS Agamemnon,Robi,R2-D2, MFH Cobra .
Looks great Andy. I have enjoyed watching the build, will you weathering her or leaving her as new? “Whenever you find yourself on the side of the majority, it is time to pause and reflect.” -Mark Twain
Hi Jase There will be some weathering added still a long way to go yet and thanks for looking in regards Andy Current builds:-C57,Zero, Lamborghini Countach, Caldercraft HMS Agamemnon,Robi,R2-D2, MFH Cobra .
Hi Andy! Your building seems to going well. The truss structures are painted perfectly as usual. A search light, especially its lens, under the flight deck looks realistic. I'm waiting for your next progress toward the goal. Best Regards, Yutaro DeAGOSTINI 1/250 the YAMATO, 1/250 the AKAGI. Hasegawa Co. 1/350 Battle ship NGATO, 1/350 Aircraft carrier Akagi, Battle ship MIKASA. Water line series 1/700 Battle ship YAMATO, HIEI, YAMASHIRO, Aircraft carrier HIRYU,TAIHO, Heavy Cruiser Myoukou, Ashigara, Nachi, Haguro & others.
 Hi Yaturo Thanks for your comments and looking in regards Andy Current builds:-C57,Zero, Lamborghini Countach, Caldercraft HMS Agamemnon,Robi,R2-D2, MFH Cobra .
 Hi All A few more pic's on progress, more platforms have been added to the bow hangar area and more ladders to the upper hangar. All the large anti aircraft mounts have now been added aswell .Some small fittings to the upper hangar added and finally the two drain pipes and booms added to the hull. There is a set of decals to add to the forward flight deck but I will be adding these at a later date as after the decks are permamently fixed I will be flipping her over to compleat the lower hull screw/rudder area then painting it before attaching the stand and flipping back regards Andy arpurchase attached the following image(s): Current builds:-C57,Zero, Lamborghini Countach, Caldercraft HMS Agamemnon,Robi,R2-D2, MFH Cobra .
She really does look fab Andy, respect for your achievements... Regards Alan
 Hi Alan Thanks for the comments , much appreciated and she is coming together now and looking the part I think. Still have to block build all the aircraft and remaining launches though so still lots to do regards Andy Current builds:-C57,Zero, Lamborghini Countach, Caldercraft HMS Agamemnon,Robi,R2-D2, MFH Cobra .
Hi Andy! Your building is excellent as usual. I have read your building plan. I thing it's perfect! I am waiting for your next progress. Yutaro DeAGOSTINI 1/250 the YAMATO, 1/250 the AKAGI. Hasegawa Co. 1/350 Battle ship NGATO, 1/350 Aircraft carrier Akagi, Battle ship MIKASA. Water line series 1/700 Battle ship YAMATO, HIEI, YAMASHIRO, Aircraft carrier HIRYU,TAIHO, Heavy Cruiser Myoukou, Ashigara, Nachi, Haguro & others.
Making great progress Andy and I'm really looking forward to seeing the finished model, though I know that is some way off yet?
She should be a stunner and will make a nice companion to your 1:16 Zero!!
Kev
 Hi Yaturo Thanks for your comments always appreciated, after the lower hull is completed I can concentrate on the top decks just one thing preventing the final stick down is the rear hangar door part that comes with the last issue regards Andy Current builds:-C57,Zero, Lamborghini Countach, Caldercraft HMS Agamemnon,Robi,R2-D2, MFH Cobra .
 Hi Kev Thanks for looking in and your comments , yes the Zero will go down well with the ship she flew from on that fatefull day in December plus all the smaller aircraft on the deck , mind you I have nearly got the Japanese fleet with the Yamato 1/700 Akagi and Shinano aircraft carriers maybe I should get a few destroyers to shield the capitol ships regards Andy Current builds:-C57,Zero, Lamborghini Countach, Caldercraft HMS Agamemnon,Robi,R2-D2, MFH Cobra .
This is looking good Andy, will be fantastic when finished - I just went to the official build to see whats ahead and its not been updated for a year, does anyone know why? Steve
 Hi Steve I Have sent you a Pm Andy Current builds:-C57,Zero, Lamborghini Countach, Caldercraft HMS Agamemnon,Robi,R2-D2, MFH Cobra .
Guest (19)
