Beautiful work on the hull Stu  Good luck with the gunports. Kind Regards Nigel
 Rank: Pro  Groups: Registered
Joined: 06/12/2012 Posts: 152 Points: 439 Location: Barrow-in-Furness Cumbria
thanks Alan, ill take a good look before i start the gun ports, i suppose having to put the new bathroom in has done me a favour and let me fall behind so i can cash in on the advice. its really appreciated though. cheers Stu :-) Cheers Stu
thanks for having a look nigel. i appreciate the encouragement cheers Stu Cheers Stu
  Ive now lined off the top off the hull. i intend to cut these off later on after all the gun ports are cut as it looks like some of them come close to the top edge. Cheers Stu Cheers Stu
 Ive now temp pinned a piece of bamboo to the hull so i can mark all the lower gun ports. im going to use a 12mmx13mm template to draw in the gun ports. ive made this dead size and then ive put a small chamfer on the inside edge the intention is that this will allow for the thickness of the pencil line and i will remove the line when final filing to size. cheers Stu Cheers Stu
Hi Stu, very clean and precise looking.... very well done... Regards Alan
Joined: 13/09/2012 Posts: 149 Points: 435 Location: Highlands of Scotland
Hi Stu, what can I say that has not been said already, very nice build. Sandy
Various balsa aircraft both rubber powered and RC Billing Jyland Billing Wasa Billing Dutch Royal Barge (gold medal winner Germany 1975) Scratch built HMS Victory using HMSO plans hull size 26" Scratch built Yamato Hull size 8'8" De Pardo HMS Bounty
Current build Sovereign of the Seas
thanks Alan and Sandy. I appreciate you looking in Cheers Stu
Joined: 24/09/2012 Posts: 491 Points: 1,452 Location: London
a smooth hull always looks great, great work stu! Processing - Progressing
Previous builds: HMS Victory Current build: HMS Sovereign of the seas
 Hi Stu just take your time with the first one and it all becomes a lot easy with the rest  Happy building . Rgd Martyn Building ? Completed. Soliei Royal . Sovereign of the Seas . Virginia . Scotland . San Felipe . Corel vasa , Santisima Trinadad X section , Vasa Next Build ? When sailors have good wine, They think themselves in heaven for the time. John Baltharpe
Thanks Admiral and Martyn. appreciate you taking a look. Cheers Stu
Hi Stu, know how you feel.... I had my heart in my mouth when it came to actually cutting that first port out....  .. Take your time with it and I'm sure it will work out just nicely.... Regards Alan
 Finally plucked up the courage to cut into the hull and now ive got half the port side gun ports cut out. Cheers Stu
  ive used a template for the gun ports, and keep trying it in then filing a bit then try again, this way i can make sure all the ports are the same size. cheers STU Cheers Stu
That's mighty fine work Stu Kind Regards Nigel
thanks Nigel, that means a lot coming from yourself. ive been watching your diary, your producing some great work. a pleasure to watch it come together. thanks stu Cheers Stu
Joined: 02/09/2012 Posts: 515 Points: 1,515 Location: Burnley
Hi Stu, Looking good! Daunting to start with, but your doing a great job. Regards claret Also working on: SOTS. Moebius 1/32 Flying Sub with PE & lights.
Waiting in the wings: Polarlights Spindrift from Land of the Giants.
finished: 007 Iconic DB5.
thanks claret. Ive been watching your build closely, can i ask how you got the caulking effect on the upper second layer of planks, i wasnt going to tree nail as its my first ever build, but you seamed to have nailed it (excuse the pun) might have a go now seeing yours. cheers Stu Cheers Stu
