7 Pages 123>»
Stu,s build Options
stujue
#1 Posted : 02 May 2013 21:29:04
Cheers Stu
stujue
#2 Posted : 02 May 2013 21:33:13
Cheers Stu
stujue
#3 Posted : 02 May 2013 21:35:29
Cheers Stu
#4 Posted: : 02 May 2013 23:24:02
Very nice clean looking build Stujue... nicely done.. BigGrin BigGrin
Admiral Anti Spiral
#5 Posted : 02 May 2013 23:43:32
Great work Stujue!
Processing - Progressing
Previous builds: HMS Victory
SennaMentalMe
#6 Posted : 03 May 2013 00:07:02
Nice work!! ThumpUp
Kev BigGrin
Captain David
#7 Posted : 03 May 2013 07:41:27
Looking good!
#8 Posted : 03 May 2013 08:15:04
BigGrin Nice build . Love the gun's BigGrin Rgd Martyn
stujue
#9 Posted : 03 May 2013 08:40:59
thanks for the vote of confidence, its much appreciated.javascript:insertsmiley('Cool%20','/images/emoticons/msp_cool.gif')
Cheers Stu
NMBROOK
#10 Posted : 03 May 2013 21:24:01
Thats looking good Stu.Suggest you check my post hull profile in sos build discussions.
Regards Nigel
stujue
#11 Posted : 03 May 2013 23:41:05
Thanks Nigel. read your post and makes sense. guess being new to this type of modelling, the assumption is lazer cut computer aided design should give us the right bits. Lesson learnt and i will correct during filling and sanding and also will be more vigilant as the build goes on.
Again this Forum is fantastic for me as a beginner. I appreciate any advice,
Cheers
Stu
Cheers Stu
Harris625
#12 Posted : 05 June 2013 08:51:08
Rank: Newbie
Nice work and great result. The sharp edges are well finished and give good effects. The quality wood increase the results and sharpness.
Hans
#13 Posted : 05 June 2013 09:48:17
Some good building there Stu. Keep it up.
Rgds, Hans
Endeavour Cross section,D51
Completed: HMS Victory
stujue
#14 Posted : 17 June 2013 16:35:29
My build was interupted while i had to fit a new bathroom. all done now and back on the build. ive just started sanding down the hull. As this is my first build 1 definatley now understand why its so importand to get everything pefect before planking. Light arm and shoulder taken all they can for today so i will be back on it tomorrow. Ill post some pics when its all done.
stu
Cheers Stu
stujue
#15 Posted : 17 June 2013 16:37:16
one good point is. i had a load of polystyrene in the packing for the bathroom and its made perfect sanding blocks.
Stu
Cheers Stu
NMBROOK
#16 Posted : 17 June 2013 20:53:02
Hi Stu
Glad to hear you are back at it now the bathrooms doneBigGrin BigGrin
Kind Regards Nigel
stujue
#17 Posted : 20 June 2013 18:55:50
ive now rough sanded the hull and used a bit of filler to smooth out the dent towards the eft end. i missed this and had planked the hull before realising there was a floor in one of the frames. anyway looks a lot smoother now. Im going to mark off the gun ports next. tricky bit by all accounts.
cheers
Stu
Cheers Stu
#18 Posted : 20 June 2013 19:32:27
Hi Stu,BigGrin
That`s looking really good, I think a few people have the same problem with the dip to the stern (me included)but not a major problem to cure.
For a first sanding your hull looks really good. With respect to the gun ports (not marked mine yet) it seems that to check it a couple of times before you cut seems to be the way to go.
Also check out Mr T`s official build as there is a slight adjustment to the position of one port to be taken into account.
Good luck and happy building Cool
stujue
#19 Posted : 20 June 2013 19:43:52
Thanks for looking in derek and thanks for the comments. yeah i will be checking a number of times before cutting the ports. really dont want to make a mistake at this stage.
cheers Stu
Cheers Stu
#20 Posted : 20 June 2013 22:20:17
Lovely work there StuJue, hull looks spot on....BigGrin BigGrin .. Take your time over the marking of the ports and double even triple check all measurements... BigGrin BigGrin .. Derek is absolutely correct, there is a couple of ports that some feel are wrong on the instructions so would suggest you check the official build and other diaries too..... I desided to move the ports on my build... BigGrin BigGrin .. Keep up the good work and keep posting.....Cool
7 Pages 123>»
