 Looking dooog Andy Current builds:-C57,Zero, Lamborghini Countach, Caldercraft HMS Agamemnon,Robi,R2-D2, MFH Cobra .
Joined: 24/09/2012 Posts: 491 Points: 1,452 Location: London
Coming along nicely Andy  keep it up Processing - Progressing
Previous builds: HMS Victory Current build: HMS Sovereign of the seas
Joined: 02/09/2012 Posts: 515 Points: 1,515 Location: Burnley
Hi Andy, Lovely planking. Keep up the good work Claret Also working on: SOTS. Moebius 1/32 Flying Sub with PE & lights.
Waiting in the wings: Polarlights Spindrift from Land of the Giants.
finished: 007 Iconic DB5.
arpurchase wrote: Looking goood Andy Thanks Andy, slow but rewarding.
Admiral Anti Spiral wrote:Coming along nicely Andy  keep it up Thanks Admiral, taking my time on this bit, no where to hide anything
claret wrote:Hi Andy, Lovely planking. Keep up the good work Claret Thanks Claret, yours is looking pretty good too
Now with issues 38+ I'm able to step things up a bit. Firstly I fitted the Transom supports and Transom, I thought I needed these fitted for the planking measurements, but in fact I didn't. Care needs to be taken fitting the supports, as their natural position is to sit square to the Back Wall of the Stern (#50) but they need to sit at an angle, so they are in line with the slots on the side pieces. I took Mr T's advice and fitted Support Blocks under the top piece. I also had trouble gluing the Transom down, as it curves a the base but is flat at the top. I found the Ply was too thin to clamp safely, so I nailed it in place. I then dry fitted the remaining pieces, marked the limit of the planking and also added a line for the start of the Black section. I did this with a Red Pen, so I wouldn't get confused with all the other lines that I have marked on the Hull Then I cut and tapered Sapele planking to finish at this line. Then I switched to 0.5mm Black Boxwood Strip for the rest of the planking, this is Marquetry Wood and is Black all the way through, so can be sanded etc. Thanks again to Nigel for the 'heads up' on this.
Lovely work Andy  .The black boxwood looks amazing!!I have a lot of work to do before I fit mine to the upper hull. Kind Regards Nigel
Stunning Andy, love the black boxwood..... gives a beautiful finish.... Nicely done m8... Regards Alan
Gandale wrote:Stunning Andy, love the black boxwood..... gives a beautiful finish.... Nicely done m8... Regards Alan Thanks again Alan, the Boxwood is lovely and as black as night right the way through, highly recommended.
NMBROOK wrote:Lovely work Andy  .The black boxwood looks amazing!!I have a lot of work to do before I fit mine to the upper hull. Kind Regards Nigel It looks even better in the flesh, great to work with too. Solid Colour or should I say lack of Colour  .
She looks beautiful Andy  When you sand the boxwood it goes a funny grey,but will return to as it was when you put finish on.Since buying the black boxwood,I have bought all sorts form OM and am mightily impressed with their products.Did you order enough black for the deck bulkheads? Kind Regards Nigel
wow beautiful work, i love the look of the black boxwood, great work Andy Processing - Progressing
Admiral Anti Spiral wrote:wow beautiful work, i love the look of the black boxwood, great work Andy Thanks Admiral, I can recommend the Boxwood.
Stunning Andy, simply stunning....  .. A little to late for me to consider the boxwood for this build but have banked the idea for other builds I have storing away.....  .. By the looks of things I think you are another who will end up with one beautiful lady for display.....  ..Love your work.... Regards Alan
Lovely job there Andy, looking forward to the next set of pics. Rgds, Hans "It's okay to make mistakes. mistakes are our teachers - they help us to to learn, even if it is painfully" Current Build: Endeavour Cross section,D51 Completed: HMS Victory Under the bench: Endeavour x 2,Sovereign of the Seas, Akagi and The Black Pearl!HMS Victory Cross Section
Hans wrote:Lovely job there Andy, looking forward to the next set of pics. Thanks Hans, slow work at the moment.
NMBROOK wrote:She looks beautiful Andy  When you sand the boxwood it goes a funny grey,but will return to as it was when you put finish on.Since buying the black boxwood,I have bought all sorts form OM and am mightily impressed with their products.Did you order enough black for the deck bulkheads? Kind Regards Nigel I agree Nigel, OM are very good and yes I now have enough for the Bulkheads.  But I think I need some more Maple.
Joined: 06/12/2012 Posts: 152 Points: 439 Location: Barrow-in-Furness Cumbria
Hi Andy your model looks stunning,  , can i ask where you got your black boxwood from, os it the same size planks as the saple cheers stu Cheers Stu
Guest (11)
