Joined: 24/09/2012 Posts: 491 Points: 1,452 Location: London
Lovely work Claret! very clean and sharp! well done Processing - Progressing
Previous builds: HMS Victory Current build: HMS Sovereign of the seas
Hi Claret, As you say, it may be slow but, look at the end result for all the effort. REMARKABLE !!!!!!!!!! Regards delboy271155 (Derek) COME BACK GUY FAWKES "YOUR COUNTRY NEEDS YOU"
Beautiful Claret and a credit to you......  .. Take as long as you need and you will be rewarded....  ..Keep posting... Regards Alan
Joined: 02/09/2012 Posts: 515 Points: 1,515 Location: Burnley
Thanks guys, your comments are very much appreciated. Claret Also working on: SOTS. Moebius 1/32 Flying Sub with PE & lights.
Waiting in the wings: Polarlights Spindrift from Land of the Giants.
finished: 007 Iconic DB5.
Hi, finally finished the first section of Sapele planking. Pleased with the result so far, and hoping once sanded and varnished it will look much better. Now to start on the bottom half with the Basswood.   Thats it for now. Claret Also working on: SOTS. Moebius 1/32 Flying Sub with PE & lights.
Hi All, More progress on the secondary planking. Taking a lot longer than anticipated, trying to ensure that the width of the planks does not taper below 1/2 a width. The bending of the basswood at the stern was done using a plank bending tool that basically forms creases in the wood. Did them very close together and did not exert to much pressure. In between glue drying I also started the tree nailing. What fun that is  I have decided only to treenail at the end of the planks (double) and around the cannon ports. Progress so far in the photo's below.    Claret Also working on: SOTS. Moebius 1/32 Flying Sub with PE & lights.
Joined: 06/12/2012 Posts: 152 Points: 439 Location: Barrow-in-Furness Cumbria
looking really good there Claret. Stu Cheers Stu
Nice work Claret  coming on well Kind Regards Nigel
Nicely done Claret and yes the treenailing is lots of fun....  ... Coming along really well so keep it up and keep posting.... Regards Alan
Lovely job there Claret, she is really looking good. Rgds, Hans "It's okay to make mistakes. mistakes are our teachers - they help us to to learn, even if it is painfully" Current Build: Endeavour Cross section,D51 Completed: HMS Victory Under the bench: Endeavour x 2,Sovereign of the Seas, Akagi and The Black Pearl!HMS Victory Cross Section
Thanks Guys. Progressing slowly!! Regards Claret Also working on: SOTS. Moebius 1/32 Flying Sub with PE & lights.
Hi, More progress although it does not look like it. Bottom secondary planking coming along slowly, and the treenailing is taking forever. Run out of the 600 cocktail sticks I had and still need more. The pictures show my progress below.       Thanks for looking in. more to follow. Regards claret Also working on: SOTS. Moebius 1/32 Flying Sub with PE & lights.
 Nice work Claret love the the treenailing  Happy building rgd Martyn Building ? Completed. Soliei Royal . Sovereign of the Seas . Virginia . Scotland . San Felipe . Corel vasa , Santisima Trinadad X section , Vasa Next Build ? When sailors have good wine, They think themselves in heaven for the time. John Baltharpe
Hi Martyn, Many thanks. I think the treenailing is becoming a labour of love!! Claret Also working on: SOTS. Moebius 1/32 Flying Sub with PE & lights.
Superb workmanship,simply superb,what more can I say Claret. Kind Regards Nigel
Very nicely done Claret, definitely worth the effort you are putting in....  .. Just for the record, I went through some 2000 cocktail sticks and still have a little more to do....  .. Keep up the good work.... Regards Alan
Joined: 23/04/2013 Posts: 287 Points: 859 Location: Hartbeespoort, NW, South Africa
Hi Claret The build is coming on nicely, well done! Regards Kobus
Current Build HMS Sovereign of the Seas - First Build
Hi Nigel, Alan & Kobus, Many thanks for looking in and your comments. Regards Claret Also working on: SOTS. Moebius 1/32 Flying Sub with PE & lights.
looking superb claret Cheers Stu
Thanks Stu. Claret Also working on: SOTS. Moebius 1/32 Flying Sub with PE & lights.
Guest (10)
