 Rank: Pro Groups: Registered
Joined: 31/12/2011 Posts: 123 Points: 369 Location: Graz, Austria
Thank you all for these very kind comments. @ Lawrence: canoe21 wrote: I especially like your DecorativElementsts on your trim. Is it possible for you to give me the with of the wood that you used to make these fantastic details. Thank you, Lawrence, but I am not quite sure what details you mean.... I have a big box with left-over wood strips from which I pull out a piece every now and then. Best regards, Bernd
Bernd wrote:I also completed the gun port lids and started fitting them to the ship. I deviated a little from the instructions by using eyebolts (the smallest eyebolts I could find) for attaching the threads. Hi Bernd! Could you please tell me, where you found those small eyebolts? Thank you, Walter Greetings, Walter
DaDokta wrote:Could you please tell me, where you found those small eyebolts?
Hi, Walter! Look here http://www.cornwallmodelboats.co.uk/acatalog/caldercraft__eyebolts_nails.html#aC83505Best regards, Bernd
Thank you, Bernd! Fantastic build as i already mentioned a few times! Greetings, Walter
Joined: 18/11/2012 Posts: 19 Points: 57 Location: Sutton, Ont., Canada
Hi Benard
Thank you very much four your reply, what I ask for was how wide is the wood you ysed to make these fantastic decorations in your Post #71.
Regards Lawrence
Lawrence, this was a 10x2 mm strip of lime wood if I remember correctly.. Regards, Bernd
Hi, shipmates! Some time has passed and although I was distracted by other things I could spend some time with my ship. I assembled the stern laterns and glued them into position  Then I added the foresail, following exactly the instructions of the kit (cause I don't know any better).     The following view of the platform will soon be blocked by the fore topsail  Next, I fitted the mizzen sail  My self-made mizzen sail turned out to be too small. There is a huge gap between it's front edge and the mast:  I'm not quite happy with this. Indeed, I noticed, that after my treatment (sewing seams, attaching leechlines and reef-bands, dyeing with tea, etc.) my self-made sail has shrunk by about one centimeter (compared to the sail that I received with the kit and from which I took the measurements). But even that additional centimeter wouldn't make the gap much smaller. Does that mean that the mizzen sail of the kit is too short? I am not sure if I made a big mistake and if I should make the sail again? Anyway, the gap could not be closed completely - because of the catharpins there must be a gap of at least one and a half centimeters. Considering this, I think I can live with this gap. Best regards, Bernd
Bernd, so nice to see your build progress...  .. Stunning from start to finish with some fabulous tips and methods that can be followed....  ..Very well done Bernd, she is a credit to your skills.... Regards Alan
Joined: 09/09/2012 Posts: 16 Points: 48 Location: New Zealand
that is stunning,
If my build comes out half as good, I'll be happy
Hi Bernd. That's really looking spectacular! With regards to the Mizzen sail, rather than having to make a whole new sail, could you alter/re do the running rigging supporting the upper boom from which the sail hangs? If the rigging was lengthened slightly the boom would drop down and the sail could then reach the lower boom taking away the gap. Might be still a lot of work but just an idea! Best of luck Robin First wooden ship: The Grimsby 12 Gun 'Frigate' by Constructo Second: Bounty DelPrado Part Works Third: HMS Victory DelPrado Part Works 1/100 scale Diorama of the Battle of the Brandywine from the American Revolutionary War Diorama of the Battle of New Falkland (unfinished sci-fi), Great War Centenary Diorama of the Messines Ridge Assault Index for the Victory diary is on page 1
Joined: 01/04/2013 Posts: 342 Points: 1,029 Location: Essex
Fantastic work Bernd  Loving this build Regards Alan England expects that every man will do his duty.
 Looking sweet Bernd Current builds:-C57,Zero, Lamborghini Countach, Caldercraft HMS Agamemnon,Robi,R2-D2, MFH Cobra .
Stunning work there, Bernd, absolutely stunning, Well done. Rgds, Hans "It's okay to make mistakes. mistakes are our teachers - they help us to to learn, even if it is painfully" Current Build: Endeavour Cross section,D51 Completed: HMS Victory Under the bench: Endeavour x 2,Sovereign of the Seas, Akagi and The Black Pearl!HMS Victory Cross Section
Hello, shipmates, thanks for visiting! Here are a few pictures of my progress. With all the rigging in the way it gets increasingly difficult to tie the knots  It took me a week or so to complete the foremast    It's pure chaos on the main mast. And every sail adds additional ropes  Greetings from Austria, Bernd
Stunning work Bernd, as with all of your build the rigging looks brilliant.... Regards Alan
Excellent work Bernd
Thank you, Alan and Tomick!
Absolutely stunning.
Only a feeling? Looks almost there to me.
John
Really looking the part now Bernd,  you must be really pleased with her. Fantastic work on the sails and rigging. Regards Alan England expects that every man will do his duty.
