25 Pages «<1011121314>»
Claret's SOTS Build Diary Options
claret
#221 Posted : 03 June 2013 20:28:40
Hi,
Finally completed the gun ports on the other starboard side over the weekend, which then enabled me to start on the sapele secondary planking.
marked the lines out as per the instructions. I then used pins stuck into the hull on the lines to help support and locate the first row of planking. I sanded the edges and ends with very fine sandpaper and then used a permanent black marker for caulking.
Glue was then brushed onto the strip and positioned into place and held there for a minute or so, but the glue was not adhering. Read in Alan's diary about the same issue and was resolved by sanding the hull with a very fine sandpaper. I did this and it seems to have done the trick. leaving over night to see if it bonds totally.
Pictures below.
Please feel free to comment.
Thanks for looking.
Claret
Also working on:
SOTS.
Waiting in the wings:
finished:
007 Iconic DB5.
#222 Posted : 03 June 2013 22:37:12
Nicely done Claret.. BigGrin BigGrin .. Sanding the hull certainly did the trick for me, second planks well secured with very little problems.... BigGrin BigGrin .. Keep up the nice work...
#223 Posted : 04 June 2013 08:09:33
BigGrin Love the work Claret BigGrin Rgd Martyn
claret
#224 Posted : 04 June 2013 08:50:09
Hi Alan & Martyn,
Thanks for looking in and the kind comments.
Checked this morning and the planks do not feel like they are going anywhere. The sanding with P400 seems to have worked and given the hull a silky smooth finish!
Claret
Also working on:
SOTS.
finished:
007 Iconic DB5.
claret
#225 Posted : 06 June 2013 22:47:28
Hi,
a little more progress. After the glue had cured on the first row of Sapele planking, the glue had bonded very strongly. I cut the cannon ports where the planking had over lapped and gently filled into the shape of the aperture.
I then glued the second layer on both sides covering the cannon ports to be cut out tomorrow once the glue has cured. Please see below.
Claret
Also working on:
SOTS.
finished:
007 Iconic DB5.
#226 Posted : 06 June 2013 22:51:01
Very nice Claret, be careful cutting the Sapele round the gunports, it is very brittle and breaks away quite easily..... Blink Blink
Keep up the good work...
claret
#227 Posted : 06 June 2013 22:57:30
Hi Alan,
Thanks for the nice reply and advise.
I had noticed the nature of the sapele. I have been using a new scalpel blade and cutting very carefully and filling as much as I can. no mishaps yet, but still plenty of cutting to go.
Claret
Also working on:
SOTS.
finished:
007 Iconic DB5.
claret
#228 Posted : 08 June 2013 10:46:41
Hi,
Second row of sapele planking cut out around the cannon ports and the third row added.
Slow going using a scalpel, but I do not have a saw blade fine enough or small enough to use.
Claret
Also working on:
SOTS.
finished:
007 Iconic DB5.
NMBROOK
#229 Posted : 08 June 2013 12:44:20
Very neat work ClaretCool .
Kind Regards Nigel
claret
#230 Posted : 08 June 2013 14:08:29
Thanks Nigel.
Slow going, but no rushBigGrin
Claret
Also working on:
SOTS.
finished:
007 Iconic DB5.
#231 Posted : 08 June 2013 15:16:21
Looking the biz Claret, very well done and lovely neat job cutting the Sapele... you got a lazer or something.... LOL LOL
claret
#232 Posted : 08 June 2013 23:37:57
Hi Alan,
Thanks for the nice comment.
A laser? I wishLOL A scalpel, fine file and very small cuts. One mishap, but glued back into pace okay.
Claret
Also working on:
SOTS.
finished:
007 Iconic DB5.
claret
#233 Posted : 09 June 2013 10:47:21
Hi,
A couple more sapele planks glued on and ready for the cannon ports to be cut out.
Slow progress, but I am enjoying it.BigGrin
Claret
Also working on:
SOTS.
finished:
007 Iconic DB5.
#234 Posted : 09 June 2013 11:16:48
Looking good Claret, may be slow going but the effort is paying off... well done.... BigGrin BigGrin
#235 Posted : 09 June 2013 14:31:51
BigGrin Nice work Claret looking goodBigGrin Rgd Martyn
der Gohfelder
#236 Posted : 09 June 2013 14:53:51
Hi Claret!
Very nice, well done! ThumpUp
Regards, Bernd
claret
#237 Posted : 09 June 2013 17:28:33
Thanks guys for your words of encouragement.
Claret
Also working on:
SOTS.
finished:
007 Iconic DB5.
claret
#238 Posted : 15 June 2013 11:11:13
Hi,
Sapele planking continuing at a slow pace, but almost finished. Should be able to start the lower planking and treenailing this weekend.
Starting look ship-like nowLOL
Thanks for looking in.
Claret
Also working on:
SOTS.
finished:
007 Iconic DB5.
NMBROOK
#239 Posted : 15 June 2013 11:17:26
Wow Claret,so what if it's been slow progress,that planking can only be described as perfection!Beautiful workmanshipCool Cool Cool
Kind Regards Nigel
claret
#240 Posted : 15 June 2013 11:21:49
Hi Nigel,
Many thanks for the kind post.
Very much appreciated from some one who has taken the build ( and mods) to the next level. Watching your diary with aweDrool
Thanks
Claret
Also working on:
SOTS.
finished:
007 Iconic DB5.
This page was generated in 0.199 seconds.
