12 Pages <12345>»
Another Del Prado Re-Fit Options
sparks
#41 Posted : 06 June 2013 21:15:15
Thanks Alan and Hans,
sparks
#42 Posted : 06 June 2013 22:31:59
OK, moving on the quarter deck.
I suppose the major enhancement on this deck is the 6 visible guns.
I have used the supplied carriages and added the eye bolts for the tackle
which was made using rigging cord and 2mm wooden blocks. Again, on the new gun barrel I added the breeching ring.
I purchased these barrels for the motif on them, thinking it my pass (at my 1/100 scale) for the GR cypher.
But in my haste to buy them, didn't realize that the "dolphins" near the trunions
dates them to a much earlier period, so I have just turned them over. I did send some artwork of the cypher to a brass etching company and got back a sample sheet, but they could not make them as small as required.
I still have to add the "running in" tackle. I had it in my mind for a long time that during battle it would not be needed as the recoil brings the gun back in, but obviously there could be misfires so it will be added, I have the ring bolts in the deck, and did do it on a mock up I made to practise on the tackle.
Notice in the photo above that the barrel is still the right (wrong Confused )way up.
Going off topic a moment, its strange how myself and Robin (plymouth57) have gone through many similar processes during our builds.
Some more shots, excuse the pun, of the guns.
#43 Posted : 06 June 2013 22:35:19
Some lovely detail there Sparks and have to say I love the colour and effect of your decking, it's stunning.... BigGrin BigGrin
sparks
#44 Posted : 06 June 2013 22:46:04
Thanks for you kind comments Alan, I did buy better quality (it wasn't difficult) lime planking than the supplied material, and have stained it light oak, I think, then satin varnish.
sparks
#45 Posted : 06 June 2013 23:20:35
To continue, to the fore of this deck, where the main mast comes up, I have made divisions in the openings either side of the mast and installed the three rigging cords that come through it, as attaching them below on the upper deck later will be difficult. Also added the eyebolts at the base of the mast needed at the rigging stage.
The larger of the ropes, the "main topsail sheet" belays to the "bits" below, that are visible from the waist, so I had to make the bits from scrap timber.
The other 2 lines, the "main jeers" and the "main clue garnets" belay to bits further back behind the main mast. as this was an afterthought, I was unable to put these in but managed to belay those lines to some eyebolts that I fixed to the upper deck through the openings either side of the mast, as this area won't be visible, I think I'll get away with it BigGrin
There should be grating over these openings but I will add this at a later stage.
sparks
#46 Posted : 06 June 2013 23:50:43
To the aft of this deck we have the ships wheel and binnacle as you pass through to the cabins below the poop deck.
Again, for want of finding anything better, I used parts from the Heller kit, the only ships wheels I could buy were only 8 spokes maximum (Victory's wheel has 10 ) the binnacle from the kit was made from 2 parts clear plastic, lighting again, and could not be passed up.
I added eyebolts to the binnacle for lashing down and rope to the double wheel.
The steps leading to the poop deck were the pre-made type used in the waist, cut to size, the platform was scratch built and the railings a mixture of kit parts and scratch building.
Centre of deck is the stairway leading down to the upper deck. The steps themselves were made according to Del Prado instruction from timber strips
and the hand rails again a mixture of kit parts and scratch building.
sparks
#47 Posted : 07 June 2013 00:09:48
Above the wheel and binnacle can be seen the hammock cranes and netting,
below this are the 21 fire buckets that are quite prominent on the real ship. As these were not included in the Del Prado version, and I could not buy buckets small enough to fit 21 into the space, I had to raid the Heller kit again.
I made my own decals from a photo I took of the GR cypher on the real buckets and after a lot of trial and error managed to get pretty good results. Due to the size involved the buckets were fitted to the rail, and hooks and rope handles added individually, before the whole assembly was fixed in place.
More soon
sparks
#48 Posted : 10 June 2013 20:17:42
Just noticed my build log had 1805 views !
Has to be a good sign BigGrin
Regards to all
sparks
#49 Posted : 10 June 2013 22:23:36
Sorry for the delay in the next post "The poop deck"
I am making some last minuet alterations. I was taking some photos to upload and noticed some things I wasn't happy with. Being able to take good close up shots with my new camera has its drawbacks too, as I hadn't noticed these things before,Huh but I suppose that's a good thing really.
Hope to be posting again soon.
#50 Posted : 10 June 2013 23:06:07
Beautiful work Alan, credit to your skills.... BigGrin BigGrin .. Look forward to seeing more of your build as time goes on..... BigGrin BigGrin
sparks
#51 Posted : 18 June 2013 23:26:10
OK, after a bit of re-working, here we go with the poop deck.
The Del Prado kit didn't give much detail to the poop deck apart from the
solid cast skylight and some cleats, that I thought were a bit oversize.
because of my lighting intentions I did not want to use the solid skylight. I did consider the Heller one that was made from clear plastic
(I'm sure that kit was designed to be illuminated BigGrin )
But from the few pictures I had seen of the poop deck, the Heller, and Del Prado versions were the wrong shape. The skylight on Victory (at least the one that's been there for the past 90 years or so) has a curved top to it. So I decided to make my own from Evergreen plastic strips of varying sizes and Evergreen clear sheet. The leaded light frame pieces are 0.5mm square and were put together on a piece of sticky paper to keep them in place then glued together with Plastic Weld
liquid.
Before fitting into place I fixed 3 false beams across the opening that would be seen on the real ship.
Unfortunately the skylight has gathered a lot of dust and dirt over the years (although it was covered up) and I have broken a couple of frame sections trying to clean it, that will have to be repaired.
The transom knees were from the Heller kit and as you can see from the top photo, I had made a couple of flag lockers. It was while taking a close up of these that I noticed some errors in the pigeon holes and a gouge out of the frame work. Around the same time I came across this old black and white plate that shows the flag lockers to be a lot longer and right up against the two centre transom knees.
Notice the curved top on the skylight.
I also found this more recent colour photo that shows the black/yellow colour scheme
that I had not done on the poop deck walls etc.
Looking at the black and white photo, it seems the knees were once painted yellow, but I like the yellow black scheme and decided to go with that.
#52 Posted : 18 June 2013 23:33:16
Lovely work ther sparks, enjoying your build....Cool Cool
sparks
#53 Posted : 19 June 2013 00:10:24
I made new flag lockers from my trusty old hard wood sheet and grating material.
I re-did the paintwork with yellow and black (these close up shots are pretty unforgiving, but it doesn't look too bad from a normal viewpoint)
Notice also some of the wiring to the lanterns.
While I had it stripped down, I decided to make the knees more accurate and add the ensign staff bracket. I used a piece of square Evergreen stock and filed a half round groove into it. I have no idea where the white metal bracket came from, but I knew it was somewhere in my "box of bits" and what I could use it for.
I fixed the parts between the tops of the centre knees and made the horse bracket from some small wire bent to shape and fixed it by drilling holes in the knees and gluing into place.
I fixed the flag lockers in place and made some small cleats to go on the face and top of the transom. It was about then that I realised the yellow ochre I had used was a lot yellower than the rest of the ship Cursing and had to go over it with a more mellow version.(again, it doesn't look that bad from a normal distance, that's my excuse anyway BigGrin )
I then made a couple of "canvas" covers from material and painted off white.
fixed one in the closed position and the other rolled up.
Finally, referring back to an older picture to show the extra cleats and eye bolts fitted around the deck that will be needed at rigging stage.
At the moment, I have made a start on the poop deck hammock cranes and netting, but still a way to go with that yet.
More soon.
#54 Posted : 19 June 2013 16:07:03
Looking great Sparks!
That's the same method for the flag lockers that I'm heading for (some time!) and I'm also going for the glazed skylight but probably out of perspex.
Some great ideas there!
Robin
sparks
#55 Posted : 19 June 2013 23:01:58
Thanks Alan and Robin,
I think that just about brings to a close this part of the build log that shows work already completed some years ago.
Another thing I did make, but will not be fitting to the ship until all the hammock cranes and netting are in place, are the chain wales or channels. I didn't like the Del Prado supplied ones or their plastic dead eyes, so made my own from my hard wood sheet and wooden dead eyes of
varying sizes purchased through Model Dockyard. Below are some pics of the portside set (starboard side is the same but reversed) starting at the front with the fore channel.
After the dead eyes were fixed in place I edged the channels with small brass rod bent to shape, then the whole assembly was painted black.
sparks
#56 Posted : 19 June 2013 23:41:38
You have probably noticed I have mentioned lighting a few times during the course of this build log, so may as well show that as it comes under works already completed.
I suppose the main reason for illuminating a period ship like Victory is to show off the stern galleries, so I'll start there. These first couple of photos are in normal light.
Then total darkness.
A side view of the galleries.
Here's one looking down at the quarter and poop decks.
Down into the waist below the skid beams.
Entry port.
Finally up onto the fore castle, where you can see light coming up through the mast
hole too.
I hope it won't be too long before I'm posting newly completed works.
Regards to all.
#57 Posted : 20 June 2013 13:38:08
Absolutely amazing, I love the lighting, Im so annoyed I didnt put lights in mine now and i have gone too far into the build to do anything about it. Oh well, good excuse to get the Santasima Trinidad I supposeBigGrin
Hans
#58 Posted : 20 June 2013 16:21:51
Beautiful job there Alan.Drool Love that lighting.Love
Rgds, Hans
Endeavour Cross section,D51
Completed: HMS Victory
#59 Posted : 20 June 2013 22:13:23
Hi Alan, a lovely looking build and the lighting is superb... not too much and not too bright.... congratulations on a beautiful result.....Cool Cool ..Look forward to seeing your progress....Cool Cool
sparks
#60 Posted : 22 June 2013 11:34:41
Thank you Steve, Hans and Alan for your comments.
Alan, I'm especially chuffed with your comment on the lighting Blushing as I was very conscious when designing it, that I didn't want the ship lit up like Blackpool tower, and wanted to replicate the dimmer light given from oil lanterns.
Thanks again to you all and I hope to be continuing with the build log soon.
Guest (8)
12 Pages <12345>»
This page was generated in 0.212 seconds.
