Hi Guys, Just wandering if there is any other type of glue for the RB7 to use other than the loctite flex as it is not available in Australia in any retail outlet?
Thanks Building the Hms Victory RB7
Hi and welcome.
See post #14 from Skyfire who is also in Oz.. http://forum.model-space...aspx?g=posts&t=6321
Thank you Tomick, I read the post you recommended but I am still confused as to the type(beginners ignorance) is it a standard super glue? Which is easy enough to find. I was just going off your recommendation in your build diaries to use a flexible type of super glue. Thank you by the way for your effort and time you put into the build diaries, they are fantastic.
 Rank: Pro  Groups: Registered
Joined: 30/04/2013 Posts: 105 Points: 301 Location: Perth
So tomick, let me get this straight.
Regular super glue is no good?
With careful application it should be okay, though you run the risk of the glue running onto surrounding areas which will damage those areas.
Joined: 20/01/2011 Posts: 608 Points: 1,753 Location: Canberra, Australia
The control bottle that I get you can let out either a small drop or a large amount, makes it easier to control where it goes.
Cool skyfire! And you say woollies sells them? What I am looking for? Do u perhaps have a brand name?
It has the name Selleys on the side of it. It comes in a yellow pack and sells for $5.49 I think it is. skyfire attached the following image(s):
Joined: 25/04/2013 Posts: 19 Points: 63 Location: Australia
Hello again RB7 fan's,
Just my thought's of using super glue gel,
I've done what Tomick recommended and purchased this "Super Glue" brand Gel with a special applicator and what great stuff! It is so neat. I wished I'd have known about this Super Glue Gel before my build because I'd have ended up with a neater front wing. The normal super glue as you know is runny and when it run's as many of you may already know it takes the paint with it and then those run lines as well as some of the join's where it had run has turned cloudy, so I now have some touching up to do which is a pain. So everyone if you want the best for your RB7 use the Gel where applicable and also, pay a tiny bit more and get a "good Brand Name glue" I've had some bad result's with some El Cheapo brand glue's and for the result's and the sake of a couple o' buck's it's worth it.
Melkerri
