Hi Everybody, I have decided after much deliberation to add to the growing list of build logs. My main motivation is that I am hoping that it will keep me on track and complete this build. All comments welcome. I've never done this before so I may stumble a little to start. Issues 1 & 2 Completed.
Joined: 24/09/2012 Posts: 491 Points: 1,452 Location: London
not a bad idea there andy! i think it'd look good and if you even wanted you could give it a brush with some blacken it or a gel type of blacken it, either way it seems tree nailing either way is a good idea, but nigel makes a good point, it may seem too much if the nails are too big and too close together Processing - Progressing
Previous builds: HMS Victory Current build: HMS Sovereign of the seas
Thanks Admiral and Nigel for your advice. These pins are 24ct Gold Plated Brass and are ridiculously cheap at 99p for 100. They are called Head Pins and are used for Jewelry making, they are also available in Silver and other finishes.
They seem like a good find Andy if you want that finish.Much more preferable to using brass pins that will tarnish.Can't believe they are actually cheaper than the pins we use for building.Amati make a really fine brass pin,but they would work out at four times the price! Kind Regards Nigel
Now that's a tool and a half Andy! Only advice I could give is when you actually cut them on the ship,drill the four holes a little inside the line.Otherwise through drill wander etc the ports might creep up in size when you square them up. Kind Regards Nigel
Hi Andy, I really like the idea of your treenailing, it looks as if you have snipped the heads of the pins off and think one of the things you would need to watch out for is the indentation the pin heads are leaving, unless they can be sanded out of course.....  .. Have to say too, the secret weapon is a nifty looking tool and as I am lover of tools I may just have a look and see where I can get my hands on one.... can see it would have loads of uses....  ... Keep up the good inovative work m8..... Regards Alan
Gandale wrote:Hi Andy, I really like the idea of your treenailing, it looks as if you have snipped the heads of the pins off and think one of the things you would need to watch out for is the indentation the pin heads are leaving, unless they can be sanded out of course.....  .. Have to say too, the secret weapon is a nifty looking tool and as I am lover of tools I may just have a look and see where I can get my hands on one.... can see it would have loads of uses....  ... Keep up the good inovative work m8..... Regards Alan Very sharp eyed Alan, the slight indentation was caused by the jaws of the Pin Chuck, I was using a very short length of drill. I didn't snip the pins, as they are plated, but used the opposite ends for the 2 different sizes. The Saw is only available from Shesto in the UK as far as I am aware. It is a very clever design, as the twin blades work in opposition so there is no push and pull that you normally get with this kind of saw, this allows it to be used at low speeds.
Halfway through the Canon Ports on one side.
 Rank: Vice-Master        Groups: Registered
Joined: 17/11/2012 Posts: 863 Points: 2,608 Location: Gohfeld (Germany)
Hi Andy! It´s looking very nice, well done! Regards, Bernd
der Gohfelder wrote:Hi Andy! It´s looking very nice, well done!
Regards, Bernd Thanks Bernd.
Good stuff Andy  Kind regards Mike MWG BUILD DIARIES: HMS VICTORY, SOVEREIGN OF THE SEAS, SAN FRANCISCO II, HMS HOOD, HMS ENDEAVOUR LONGBOAT, HMS VICTORY X-SECTION, 007 DB5, NISSAN GTR, CUTTY SARK, RB7, AKAGI, BARK HMS ENDEAVOUR, HUMMER H1, MITSUBISHI ZERO.
Lovely and neat as always Andy... WTG, looking first class.... Regards Alan
Very neat work Andy  ,I bet that tool makes the job a lot less tiresome. Kind Regards Nigel
looking great there andy! nice work with the tool Processing - Progressing
MWG wrote:Good stuff Andy  Kind regards Mike Thanks Mike.
Gandale wrote:Lovely and neat as always Andy... WTG, looking first class.... Regards Alan Thanks Alan, catching you up slowly, maybe
NMBROOK wrote:Very neat work Andy  ,I bet that tool makes the job a lot less tiresome. Kind Regards Nigel Thanks Nigel, indeed it does, I mean did now  .
Admiral Anti Spiral wrote:looking great there andy! nice work with the tool Thanks Admiral
