I’m near the end of issue 18. I found the Build Discussions of the best way to fit Plank 5 very helpful, especially Karl’s advice. I trimmed the bow plank and bevelled the upper edge to fit under the lower edge of plank 4, and it went like a dream. But this has big implications, seeing that I’m using bamboo. Should I bevel the top edges of all planks in the same way from now on? I wonder what others are doing. Grateful for any comments and advice. cec
neofytos wrote:I’m near the end of issue 18. I found the Build Discussions of the best way to fit Plank 5 very helpful, especially Karl’s advice. I trimmed the bow plank and bevelled the upper edge to fit under the lower edge of plank 4, and it went like a dream. But this has big implications, seeing that I’m using bamboo. Should I bevel the top edges of all planks in the same way from now on? I wonder what others are doing. Grateful for any comments and advice. cec Hi CEC, I to have used bamboo for the whole of the first layer of planking, to that end as suggested I bevelled every plank of that layer. Everything seems to have stuck together without any problems. Hope this helps. Regards delboy271155 (Derek) COME BACK GUY FAWKES "YOUR COUNTRY NEEDS YOU"
Dec, I bevelled the lower edge of each bamboo plank and it worked a dream for me, did the same when it came to tapering the planks....
Joined: 08/01/2013 Posts: 13 Points: 39 Location: Southport
Gandale wrote:Dec, I bevelled the lower edge of each bamboo plank and it worked a dream for me, did the same when it came to tapering the planks....
Alan Thank Goodness for that !!!!!! I did the same thing and reading the posts, I was beggining to think I was on my own !!! Collecting HMS Victory Up to Issue 14 so far Wish List SE5a WW1 Aeroplane
Right: it's bevelling for me from now on. (Upper edge or lower edge? I'll have to experiment.) Thanks for all the replies. C
