20 Pages «<1011121314>»
Admirals HMS Sovereign of the seas adventure Options
#221 Posted : 23 May 2013 21:06:10
Admiral Anti Spiral wrote:
does anyone know how you're meant to plank around the bow of the ship and still keep it at 30mm? because it seems it would take some intense curvingConfused
Hi Admiral, I did find the same problem and I decided to let the planks go where they wanted to go... When you consider the wales are to be applied and painted red in between then the rise shouldn't be noticeable....BigGrin BigGrin .. At least that is how I have approached it....Cool Cool
Very nice work there....
Admiral Anti Spiral
#222 Posted : 25 May 2013 13:16:12
thanks alanSmile i think i'll just go ahead and do the same, i guess its not too big a problem.BigGrin
Processing - Progressing
Previous builds: HMS Victory
Admiral Anti Spiral
#223 Posted : 25 May 2013 13:23:22
Glad to say my present has arrived, very pleased with how they are but i thought they would be brass, to be honest not sure what they are, but they look plastic.
0.5 brass rivets with a head diameter of 0.7mm, they fit great, i've been using a 0.5mm drill, i thought they would be much tougher than my last drills, but no, broke straight away, but i've managed to fit the broken piece in the vice anyway.
160 rivets for £7, much better than the 50 for £5, but even better i've found 200 for £3 which are also plastic so i'll probably go with those, i'll have to paint the heads black and glue them in.
but not so soon, i've only drilled holes where the planks connect.
NMBROOK
#224 Posted : 25 May 2013 13:30:30
Hi Admiral.you will probably find,like I am, that a new drillbit snaps almost straight away,but the broken end will drill hundreds of holes.Interesting idea with the plastic rivets,look forward to seeing how they turn out.
Kind Regards Nigel
#225 Posted : 25 May 2013 22:39:46
Hi Admiral, looking good.... Like the idea with the plastic rivets but judging by the amount of treenails I've just done on the top of one side of the hull your're going to need a lot of rivets...... especially if you intend treenailing the lower hull too... BigGrin BigGrin .. Will be watching to see how your idea works out... Cool Cool .. Lovely work all round... BigGrin BigGrin BigGrin
Admiral Anti Spiral
#226 Posted : 26 May 2013 00:00:11
yup thats a good point, i would use toothpicks as you and mike have done but i'd rather have something more of quality and accurate, only problem is the price, but lucky i've found them at a MUCH cheaper price and more per pack than originally where originally for 4000 i'd have to pay £400, but now that i'd found them much cheaper, personally i think its something worth doing BigGrin
Admiral Anti Spiral
#227 Posted : 26 May 2013 00:01:22
Kind Regards Nigel
thanks nigel, im thinking of buying more 0.5 drills but so far this broken one seems to be doing the job now Smile
#228 Posted : 26 May 2013 00:06:56
Hi Admiral.. it was from the cost angle I was thinking about and I agree I think it would look superb....Cool Cool .. Lots more work having to paint all the rivet heads but am seriously looking forward to seeing how it all looks on your build....Cool Cool .. With regards to .5mm drills breaking, I found the same but did find after the breakage the remnance of the drill would still drill all the holes necessary.... BigGrin BigGrin
NMBROOK
#229 Posted : 26 May 2013 01:59:32
Hi Admiral,
Have you seen MRTs post on scale hardware?I have had a look and they do brass square headed bolts.Think these will look great on the rudder hinge pintles etc.Definately going to be investing in some of these.
Kind Regards Nigel
Admiral Anti Spiral
#230 Posted : 26 May 2013 18:36:18
NMBROOK wrote:
Hi Admiral,
Kind Regards Nigel
nope, never saw it until you just mentioned it, but i have seen the website, very good but a bit expensive for my likes, though they do have some things which would be hard to find elsewhere.
#231 Posted : 26 May 2013 19:09:55
Hi Admiral,BigGrin
Love the work to date, as for 0.5mm drill bits try this ebay item number 200884965978 . They are £5.89p for 10 and free p+p.
You may be able to get them cheaper but that was the best when I bought mine.
Admiral Anti Spiral
#232 Posted : 28 May 2013 19:18:12
delboy271155 wrote:
Hi Admiral,BigGrin
Many thanks derek, i've bought some for even cheaper, but im not sure about the quality, my 4.5mm just broke aswell but the rivets dont fit in so smoothly so i've been using a 5.5 which seems to be holding very well, and i may even carry on using it when the 5mm come through BigGrin
Admiral Anti Spiral
#233 Posted : 28 May 2013 19:32:49
Update: Tree-nailing
Finally finished planking one side of the ship(95%) feels great to finally get it done when i thought i would of been done weeks ago, but then i realise... still one more side to go AND the under side planking, which ive stripped off, not happy with the work ive done around the stern post and keel, it doesn't have a smooth clean finish with the stern, so im going to attempt to sort that out, but not sure howConfused
Other than that, not sure whether i should start laying the rivets first or add a layer of varnish, i'll probably add a layer of varnish seeing as i only have 159(lost one) rivets and have no reply yet for the 200 rivets im waiting for, but until then i may carry on drilling.. and drilling more holes and finish planking the other side of the ship.
Also reminds me to premake gun ports, that was more of a pain than anything else ThumbDown
claret
#234 Posted : 28 May 2013 21:33:29
Hi Admiral,
Nice looking planking.
Claret
Also working on:
SOTS.
Waiting in the wings:
finished:
007 Iconic DB5.
#235 Posted : 28 May 2013 22:21:02
Looking Fab Admiral, love the caulking between the planks.... Look forward to seeing your treenailing.....BigGrin BigGrin .. Very well done there.... Cool Cool
Admiral Anti Spiral
#236 Posted : 29 May 2013 00:20:01
claret wrote:
Hi Admiral,
Claret
thanks for the comment claret :)
Admiral Anti Spiral
#237 Posted : 29 May 2013 00:22:18
thanks alan BigGrin its not perfect all around, stands out in some places more than others but i am pleased with the outcome, give a nice effect BigGrin BigGrin
NMBROOK
#238 Posted : 29 May 2013 01:14:13
Hi Admiral
The planking looks brilliant.If it were me,I might be tempted to varnish before treenailing.The first coat of varnish can lift the grain a little so you may need to knock this back with some fine abrasive and apply another coat.This would be almost impossible with the 'rivets' in place.
Kind Regards Nigel
Hans
#239 Posted : 29 May 2013 09:01:43
Beautiful job there Admiral, when you varnish that grain is going to coem through beautifully. Well done.
Rgds, Hans
Endeavour Cross section,D51
Completed: HMS Victory
Admiral Anti Spiral
#240 Posted : 29 May 2013 23:31:33
thanks hans BigGrin i hope it will, just not sure which type of varnish to use yetBlink
This page was generated in 0.278 seconds.
