epoxy resin crystallized Options
willie
#1 Posted : 22 May 2013 18:08:08
I bought 30 minute epoxy last year went to use it and the resin was hard and crystallized, O NO have to through it away but went into the web and found out you just need to heat the tube in hot water for an hour for it to be liquid again and get rid of all the crystal or it will do it a gain but when it is crystallized you can store it indefinitely Confused
This page was generated in 0.857 seconds.
