Captain David wrote:It's coming along nicely, Derek. I hope my planking will be as good. Hi Cap`n, Thanks for the nice comments, I had a few moments in the planking where things took a bit of a wobble, but, took note of advise from the more experienced builders and took it slowly slowly and I think it was advise well listened to. Good luck with your ongoing build. Regards delboy271155 (Derek) COME BACK GUY FAWKES "YOUR COUNTRY NEEDS YOU"
Joined: 02/09/2012 Posts: 515 Points: 1,515 Location: Burnley
Hi Derek, Planking looking good. cutting canon ports next!!! Regards Claret Also working on: SOTS. Moebius 1/32 Flying Sub with PE & lights.
Waiting in the wings: Polarlights Spindrift from Land of the Giants.
finished: 007 Iconic DB5.
claret wrote:Hi Derek,
Regards Claret Hi Claret, Thanks for looking in,the planking looked like a devil of a job when I first took it on, but, the gun port cutting is scaring the living c**p out of me. Cutting into all that hard work  and hoping it`s all in the right place  . Well looks like another session of mark it, check it, check it again and again then take the bull by the horns, Regards delboy271155 (Derek) COME BACK GUY FAWKES "YOUR COUNTRY NEEDS YOU"
Looking good Del  .Glad to see the repair is holding up. Kind regards Nigel
NMBROOK wrote:Looking good Del  .Glad to see the repair is holding up. Kind regards Nigel Hi Nigel, Thanks for taking a look,the repair seems stronger than the rest,just hoping when it comes to cutting the gun ports I don`t need to do any more repairs. Regards delboy271155 (Derek) COME BACK GUY FAWKES "YOUR COUNTRY NEEDS YOU"
Hi all, Had a good day on the the planking today  . The results are that I have reached the end of planking for issue 33. Still have the infill and trimming bits to do but happy with results to date. Here`s the pics below, comments and advise welcome as usual. Regards delboy271155 (Derek) delboy271155 attached the following image(s): COME BACK GUY FAWKES "YOUR COUNTRY NEEDS YOU"
Coming along well Del  I have a hard rubber double length sanding block I got from a car bodyshop suppliers.They are fairly inexpensive and do help in smoothing out any high and low spots,I find a normal block a little short to get true lines without alot of constant checking.I also used a piece of garden hose with the paper wrapped around it for the awkward shapes at the stern. Kind regards Nigel
NMBROOK wrote:Coming along well Del  I have a hard rubber double length sanding block I got from a car bodyshop suppliers.They are fairly inexpensive and do help in smoothing out any high and low spots,I find a normal block a little short to get true lines without alot of constant checking.I also used a piece of garden hose with the paper wrapped around it for the awkward shapes at the stern. Kind regards Nigel Hi Nigel, Thanks for looking in and some good tips WTG. Regards delboy271155 (Derek) COME BACK GUY FAWKES "YOUR COUNTRY NEEDS YOU"
 Nice work on the planking lovely jubley  Rgd Martyn Building ? Completed. Soliei Royal . Sovereign of the Seas . Virginia . Scotland . San Felipe . Corel vasa , Santisima Trinadad X section , Vasa Next Build ? When sailors have good wine, They think themselves in heaven for the time. John Baltharpe
Joined: 17/11/2012 Posts: 863 Points: 2,608 Location: Gohfeld (Germany)
Hi! Well done, go on this way Regards, Bernd
Its looking good Derek, nearly at the top and then the sanding phase.... think she will sand down very nicely indeed... Regards Alan
Good job there Derek, impressive. Rgds, Hans "It's okay to make mistakes. mistakes are our teachers - they help us to to learn, even if it is painfully" Current Build: Endeavour Cross section,D51 Completed: HMS Victory Under the bench: Endeavour x 2,Sovereign of the Seas, Akagi and The Black Pearl!HMS Victory Cross Section
NMBROOK wrote:Coming along well Del  I have a hard rubber double length sanding block I got from a car bodyshop suppliers.They are fairly inexpensive and do help in smoothing out any high and low spots,I find a normal block a little short to get true lines without alot of constant checking.I also used a piece of garden hose with the paper wrapped around it for the awkward shapes at the stern. Kind regards Nigel Hi Nigel, Thanks for looking in and the sanding tips, Regards delboy271155 (Derek) COME BACK GUY FAWKES "YOUR COUNTRY NEEDS YOU"
Martyn Ingram wrote: Nice work on the planking lovely jubley  Rgd Martyn Cheers Martyn, Thanks for looking in. Regards delboy271155 (Derek) COME BACK GUY FAWKES "YOUR COUNTRY NEEDS YOU"
der Gohfelder wrote:Hi! Well done, go on this way Regards, Bernd Cheers Bernd, Thanks for looking in. Regards delboy271155 (Derek) COME BACK GUY FAWKES "YOUR COUNTRY NEEDS YOU"
Gandale wrote:Its looking good Derek, nearly at the top and then the sanding phase.... think she will sand down very nicely indeed... Regards Alan Hi Alan Thanks for looking in,have had a little look for the highs and lows and it does look pretty good for a first attempt.Bit more at the stern due to the twists and turns but should be Ok. Regards delboy271155 (Derek) COME BACK GUY FAWKES "YOUR COUNTRY NEEDS YOU"
Hans wrote:Good job there Derek, impressive. Hi Hans, Thanks for looking and and the nice comments. Regards delboy271155 (Derek) COME BACK GUY FAWKES "YOUR COUNTRY NEEDS YOU"
Hi All, Just a very short update, with thanks to those who assisted with my question on the final upper planking session. Problem now understood so there`s a pic one side completed below. Next update may be delayed, I`ve got nearly 100 babies to look after. Sorry baby Angel fish, missed that bit out. Regards delboy271155 (Derek) delboy271155 attached the following image(s): COME BACK GUY FAWKES "YOUR COUNTRY NEEDS YOU"
Looking good Derek and you did the right thing by adding the extra plank...  .. As long as you are above the ribs then you will be fine... Well done m8.... Regards Alan
WTG Del  .As Alan said will sand down well,but don't forget about the hull profile post. Kind Regards Nigel
